Whirlpool Dryer Rescued from the Scrap Metal Yard.
ultramatic....
you did an amazingly "OUTTA SIGHT" job on both of them cute portable dryers!!! i can't get over how good you got them both looking & working!!! to me they both are as good as new!!!
2 GREAT JOBS THERE!!!
Hey thanks Christina!
Ooooops. I did it again...
So this little fellow followed me home from Queens yesterday...
ID Mod sticker missing. I suppose it's an early 80's? Any other way to accurately date this?
I shudder to think what it looks like inside.
I know what you're thinking, I must have lost it, yet another dryer, and I didn't find this one in the trash. I PAID for it. BUT, he came with a friend...
that dryer rack looks awfully familiar......
HA HA HA.....
i'm glad to see that this portable whirlpool dryer & dryer rack went to someone in the group, who will use it for what it was intended for and appreciate it for exactly what it is.
GOOD SAVE/SCORE THERE ULTRAMATIC!!!
;o)
p.s.
as for the chain question & where it would go, sorry i have no idea, so i can't help you with an answer. i'm just barely even learning about these portables myself!!!
:o)
You can't tell by the picture, but the rear is covered in cooking grease. Yep, this dryer lived in the kitchen.
Whirlpool was still using an asbestos heat shield. Not as filthy as I thought it was going to be, mice droppings not withstanding.
Belt looks fine, no fraying, no cracks.
Not bad.
Not bad at all.
I don't think this dryer was used much.
After a quick vacuuming. Rabbit cage is of course, clogged. Saving that cleaning hell for later.
[this post was last edited: 3/15/2014-04:19]
Matching Kenmore washer, in white
Hi, if you travel all the way down to Buenos Aires you can get for US$ 35 (or 350 pesos) a matching washer to your Kenmore dryer. Seller says it has been stored for the last 20 years! Incredible how these things turn up locally, the unit is for 110V/60Hz. Maybe someone brought it from the States and didn't know how to connect it with a step-down transformer.
Emilio
http://mla-s2-p.mlstatic.com/lavarr...ga-superior-11878-MLA20049808403_022014-O.jpg
http://articulo.mercadolibre.com.ar/MLA-495975753-lavarropas-portable-kenmore-carga-superior-_JM
De nada Ultramatic!
I don't have the slightest chance (spacewise) of storing this washer, otherwise I would immeditely buy it!
Congratulation on your restorarion of the two dryers!
Emilio
I look twice or thrice at these small washers and dryers (apt size) because of this thread and your postings on these machines. Thanks for posting alot of helpful visual and text info, Louie. I wouldn't mind a pair of these - but I'd like to find a pair that weren't quite so spartan looking on the outside(if that even existed?).
@thor: Thanks again Emilio. Trust me, I'm running out of space too! LOL!
@ovrphil: The "fanciest" versions of these machines seem to be the Lady Kenmores. These dryers with the rare windowed door must look great!   And you're very welcomed Phil, glad you're enjoying the posts.
[this post was last edited: 3/15/2014-14:53]
i already know.....
you're going to have this new whirlpool dryer gleaming & shining in no time, ultramatic!!!
i'm looking forward to the pictures & updates!!!
:o)
Meanwhile, in 1978
Notice that a full size washer and dryer were actually cheaper than the Thin-Twins. Also note, the dryer rack style has been changed. Odd, either the rack I have is much older than the dryer, or they were still available in the 1980's.
WP Built Compact Dryers
These never got very fancy, a few KM versions did get a temperature selector switch, and and 240 volt versions often got a time-temperature auto-dry cycles. The 120 volt dryers did not really need a temperature control as the maximum heat on a 120 volt dryer is not likely to ever damage clothing.
Since the DOE has required all clothes dryers sold in the last 10 years or more to have an auto dry cycle, WP opted to add the electronic sensor system that they use on many of their large to all 120 volt versions of these dryers. This feature can be added to 240 volt and gas versions of this dryer if you are handy and clever. It is also fairly easy to convert the 120 volt versions to 240 volts by changing the heating element and a few other simple wiring modifications.
Note they never made these compact dryers in 110 volts as the US switched to 115 and then to 120 volts long before these dryers were ever made.
The very rare models with the window door are a John & Jeff modification only available at extra cost, LOL.
