Whirlpool World Washer
I know, I know. I need another project like I need another hole in my head. But it looked decent. Although the tub is dry, there still was water in the hose, and I can hear water sloshing inside the washer. I have read these washers can be a toss-up in terms of reliability. They can be trouble prone or fairly decent. I haven't tried it, but for some reason I think it works fine. We shall see.
Have fun!
The water you hear sloshing might be the balance ring like in the Design 2000 style machines. They were sorta getting down to the minimalistic approach with these machines in that there is not a whole lot under the tub to power these things. As was said before, it is a free toy and we have all seen worse looking machines. As I remember, the motor makes one turn in each direction to cause the agitator to turn, you can't really use the term oscillate, back and forth.
Thanks guy's!
What impressed me was the big basket. How many pounds do these machines take? I'm a little bummed out about the lack of a mechanical timer. As you can see, it is configured as a portable, with the hose for faucet hook up. But it can be configured to permanent I'll give it a test run later today.
Looks like it's actually a more robust system mechanically than the VMW platforms that are now the common agitator top loaders. From the parts diagrams, the gearbox looks to be solid metal, and the pump is horizontally mounted, which I would love my 4800 to be. The pump in the modern VMW machines is vertically mounted directly to the tub bottom, which causes this terrible rhythmic coughing sound when the pump is running "dry".
Let us know how it runs!
Found videos of that machine and its Kenmore version. I can't believe these are late 90s machines! It seems the design leading up to the current VMW platform isn't as new as one would think.
<iframe src="" width="420" height="315" frameborder="0" allowfullscreen=""></iframe>
Friends of mine had one of those some years back, did laundry for a family of 4 with it. I used it a few times and it was a fine machine. Pretty quiet and could actually wash a lot. They didn't have room for a full sized washer and dryer, so they had a full size dryer and compact washer side by side, installed permanently. As far as I can remember, it had a crazy fast spin. I always wanted one of my own, but it hasn't happened yet. Hopefully yours works :)
willing to bet the belt is slipping....you might be able to loosen the motor bolts and tighten it a bit...
not sure exactly what this configuration has underneath....
no spin could be the belt slipping, or the shifter not engaging....usually it works in part, the shifter engages while the drum is rotated slightly to lock it all together, if not working properly, everything is not matching up....
should be similar to a cabrio belt drive machine....
Thanks for the vid...
Funny Martin, I had come to the same conclusion. I thought this was a Direct Drive, but there IS a drive belt. From what I have seen from the parts blow-up, there is no coupler. I hope it's not the splutch. If it's the belt, easy fix.
Cool Find!
Congrats on the find of your washer.  I have always
thought these were very cool washers!  I bet it will be
a lot of fun!
