Whirlpool World washers
WP introduced this machine a few [ in the mid eighties ] years after they introduced the DD washers, these washers were cheaper to build and had a faster spin speed, but unfortunately they did not have great durability.
They were all built in Mexico and all had the same 2 cubic foot tub capacity. The machine was sold in four different cabinet configurations. They sold two different models with a rear control panels, they were both 24" wide had mechanical timers but came in a standard height and a shorter machine as well. They also sold the model that Louie has with the electronic controls at the rear and this last model had a SS wash basket.
The biggest weak area of these machines was a main water seal that was at the bottom of the wash basket that often failed because of mineral buildup [ generally caused by too little detergent usage in harder water conditions ] and once water got into the bearings that was the end of the machine.
The new WP BD TL washers are a greatly beefed up version of these washers, bigger more powerful motor, stronger belt, greatly beefed up transmission [ note, both transmission designs have ALL plastic gears ] seal and main bearings. The other great thing about the newer BD washer design is that it is very easy to replace a transmission and seal and bearing assembly, so the new machines are no longer a throw away machine.
But overall these little world washers are fun and effective washers, you will have fun with it Louie. If you need any parts we have boxes of them, we still recycle a few of these machines every month because of bad main bearings. [ Louie if you want to see if the motor capacitor was really replaced before just compare the code date on the old part to the manufacturing date of the machines serial #.
John L.
