WTH? Kitchen Aid Superba
We often see DWs in this condition and worse, the first thing the users were doing wrong is they were pre-rinsing their dishes, How do I know this, because this DW was not working properly And the only way it was putting out dishes that were at all clean enough to use was because they were going in clean.
If you use a DW properly always putting visibly dirty dishes you will quickly know when something is not working with your machine.
My Aunt in Pennsylvania had a KDS-18 that was completely black inside, it turned out to have a bad wash-arm-support, bad inlet valve and clogged filter. It was so bad we trashed the DW and installed a new WP DW.
I had no idea pre rinsing did this!
<span style="font-family: 'trebuchet ms', geneva;">Not that I would ever have that problem at my house but I really never expected that.  All I could think was how could I eat off of dishes that came out of a machine that looked like that!</span>
I know John is adamantly against pre-rinsing, but....
To be clear. pre-rinsing or pre-washing <span style="text-decoration: underline;">DOES NOT CAUSE</span> this condition!
To rephrase what John said, if you load your dishwasher without pre-rinse anything, you will quickly be able to tell if the dishwasher is not operating properly (dishes still dirty after the cycle is done).  This one obviously has not been working correctly for a long time, with all that mold / mildew in it.  Yuk!
Kevin
How can the machine be in "mint" condition when its a mold hole on the inside?Think the seller has been breathing too much of that black mold in there!You would have to PAY me to take that washer-may have to be buried in the hazmat dump!
Kevin, John's Aunt Arlene's policy, which her family followed, was to practically scald the dishes before putting them in the dw. We were sitting outside on the deck when it was started and even from outside you could hear the clunking of the wash arm as it hit the underside of the lower rack as it tried to turn because the wash arm hub and the wash arm support were eroded away. By rinsing the dishes and then using enough detergent to clean dirty dishes, the detergent pulled the oils out of every bit of vinyl, synthetic seal and every bit of plastic. They become literally eaten away. As John said, they had no idea that the dw was not cleaning because tableware went in ostensibly clean.
The dishwasher pictured here probably has similar failures compounded by non-chlorinated detergent which, coupled with lower water temperatures, allowed the mold and slime to grow. The detergent not being washed out of the dispenser is another indication that the wash arm is not turning.
I am just amazed....
<span style="font-family: 'comic sans ms', sans-serif;">I've been watching this auction since it was originally posted at $125.  They then re-listed for $200 and now has it listed for a Buy It Now at $245.</span>
<span style="font-family: 'comic sans ms', sans-serif;">Is it just me who thinks this is nuts?  Would somebody really buy this machine at that price and attempt to clean it up?</span>
<span style="font-family: 'comic sans ms', sans-serif;">Maybe I should just mind my own business and hope the guy gets lucky but it never ceases to amaze me how some people think they have a goldmine on their hands because something is "Older" or "Vintage."</span>
http://www.ebay.com/itm/282417368834?ul_noapp=true
I'd save the steel panels and trim kit and set the rest on fire….I have one of those machines, and love it. But as was noted above, this level of mould accumulation is from someone closing the door on a damp and faulty machine and walking away for weeks/months on end. Bet there's a quart of swamp quality water sitting in the sump and drain hose...
Screw the Clorox make it a gallon of gasoline and a stick of dynamite!
I wouldn't want to see the home that thing came out of...
Stained DW
The black stains in this DW are not likley mold, they are more likley caused by conditions in the water supply coupled with mechaneal problems with the DW.
This DW could be saved if you wanted to save it, bleach would probably do little or nothing for staining if for example it is caused by magnesium in the water. In any case one should never consider putting a gallon of LCB in a DW, 1/4 cup would be about all you would ever need to sanitize and remove stains that LCB will remove, putting in a gallon will only destroy any rubber parts of this DW that may still be good.
