henene4
So, today my grandma was doing some washing, then I returned from work and wanted to start a load with my comforter in her machine.
Went to the AEG, set my regular cycle for super rinsing (Jeans, 60C, extra rinse, gives me 7 rinses).
Hit start. Machine locks. Pauses for a second. Jumps to 1 minute, drains and locks the controls (couldn't even pause the cycle).
Tried turning off and on again, now it wouldn't start at all. It would make the audible signal that I pushed the start button, but wouldn't do anything.
Unloaded, erorr code readout: E51.
Erased that, tried restarting, same story again.
Read up on E51: Motor triac (short circut) or motor fault. Seems to be a pretty common fault with ELux machines with brush-type motors.
Opend the top, and been greated by some metalic residue arround the plastic housing of the PCB/MCU. So, yeah, that is pretty obvious.
Checked on the part price (about 220€), and checked if I could get the old one out. However, it has been so geniously designed that while you can remove some conectors (pressure switch, valves, door lock), the wires going to the motor and the heater are conected within the PCB housing, which you can't open within the machine due to space limitations. So you'd either have to remove the cabinet or disconnect the heater and motor first.
Not obvious at all what this is about, or is it?
So, talked to my grandma, who talked back with a uncle of mine who works in the electronics business and who actually bough that machine (12.10.2012, so 4 years and 4 months, plus a week or so).
He agreed that it most likely won't make sense to repair that. And given it's a 1600rpm machine (L71670FL) with a sealed tub, the bearings are only a matter of time away from failing.
I could not for the sake get it to spit out it's running time hours, but last time I checked it was at about 3000h or a bit lower.
Now, as my grandpa returns from a hospital stay in a few days, my grandma wanted a new machine ASAP.
She wanted a simmilar sized drum as now (7kg), 1600rpm spin, and if possible a curtain cycle, as well as the option to add laundry.
The laundry adding option was soon crossed out. She didn't want a Beko, that ruled out Grundig as well.
Gorenje fell out due to spin speed choices (lowest possible setting was 800rpm, which my grandma verry much disliked).
In the end, she decided on another AEG. An L61670FL.
1600rpm, 7kg. Basicly, an updated version of what she had before. Inverter motor, still a sealed tub, curtains cycles, even has the PowerShower thing (basicly like the old Bauknechts).
It's default cycles are ridicously long (3:40h for Cottons 60C, 3:30h for Cottons 40C), but it has the Time Manager thing (though only called Time Saver on AEG machines) with 4 different cycle times selectable, which will get used. A lot. Pretty much every time.
I predict the cycle times will be 3:40h, 2:40h, 2:20h, and 1:20h respectivley. That would correspond with the old one, except the longer version being added.
Ordered it through MediaMarkt, extended warranty, delivered for pretty much exactly 475€. Should arrive in a few days, wednesday or thursday.
It's the same old song. About 3000 hours of runtime seem to be industry standard for machines these days, and before the death of my father and me and my brother moving out, this machine saw a lot of use. And it washed pretty well. Rinsing was something to get used to, but the idea of rinsing more often with less water soon grew on me. And 1600rpm are certanly a great thing, they do make a difference.
Let's see how things work out. I'll keep you posted!
