“softener leads to machine failure“ Is this true or is it hogwash?
adam-aussie-vac
Dec 14, 2017
1,066
Canberra ACT
Hey guys just scrolling through a YouTube and I found this and thought this would be a good topic to put here, I’ll post the video under the link thing in the video they claim to tell that softness destroy washing machines while he’s busy steam cleaning and scrubbing the machine
I’ll also be adding a second video as well where it looks like the guy put a bunch of fabric softener into the machine to make it look like it damages it :
Bad usage habits in general cause as much destruction to washers as specifically fabric softener.  Many users who overdose on softener are doing so in an attempt to cover the foul odor that results from their overall bad usage habits.
My mother doesn't use liquid softener.  She does wash primarily in cold water (admonished by dad to do so for saving money, triggered by the advertising propaganda) and uses low-quality detergent such as Arm & Hammer liquid and not enough dosage (it's high-sudsing, propaganda says there shouldn't be any visible suds).  This is a Kenmore toploader after 6 years of use.  It had been refurbed by me and in pristine condition when she started using it.  None of that brown smutz on the basket has any relation to softener.  (I'd wiped some off before taking the photos.)
Like people don’t realise
“that’s just built up dirt, same kind of way that brake dust builds up on car rims” and did you see the second video where looks like all the fabric softener has congealing destroyed the machine ( yeah right ) it’s like everybody expects the washing machine to be like the inside of a dishwasher where it’s all nice, sparkly and clean, it’s like how the dishwasher doesn’t have to deal with a log the dog dropped on the carpet and plus I don’t really catch that “ you must use 30 mL/2 tablespoons of high-efficiency detergent“ that honestly especially in an old-fashioned top loading water guzzling washing machine that’s a drop in the Ocean when you need a river of detergent (the recommended usage where available) Because if you don’t use enough detergent and then you something like vinegar it’s not really gonna do anything just gonna make things smell like vinegar and still look dirty
Great pictures Glenn!! Pictures 2-5 show why I so much prefer using solid-tub washers, such a Frigidaire, Speed Queen, Philco, Norge, Hotpoint, Apex, Kelvinator, etc. While solid tub machines can have grime build-up on the outside of the spin tub and in the outer tub like what Glenn's pictures showed, the inside of the solid-tub is pristine and there is never contact with clothes/water from the wash tub's interior to any grime on the outside of the tub. Once the water is expelled from the solid wash tub there is no way what so ever of anything expelled ever coming in contact with the inside of the wash tub again.
The only exception to this are machines like the solid-tub GE filter-flo that is recirculating water between the outer tub and inner tub however the recirculation water is filtered and it is not bathed in this water like perforated tub machines.
I’ve cleaned
My 2000 Kenmore like he did in the video twice since new.
Last time was only a month ago.
Both times where nowhere near that bad.
I don’t use FS
I think no matter what one uses it a good idea to check them on occasion and clean them out.
Since last cleaning I’ve been adding STPP to each load to prevent mineral scale.
I think it’s a good idea to use a good powdered detergent (sodium carbonate) once in a while with hot water, even if you running a empty load to clean out oily gunk.
I have no idea if fabric softener will have an effect on our machine, but we have been struggling with over sudsing for the past year almost now, have checked everything but nothing seemed to work. Changed the detergent that we used from OMO auto to Skip auto, it is a Unilever product and is the most expensive automatic washer detergent in South Africa. Then I have found a video clip on you tube from Bosch stating that if over sudsing occurs one should add a cup of fabric softener with about a litre of water. Ever since we started regularly using fabric softener the sudsing seems to be something of the past.
I hope I am not destroying our Miele in the process.
Regards
Aldo
Have you tried using half the recommended dosage of your detergent?
You might have a detergent build up already in the fabrics. This can cause over sudsing.
Try washing a load in warm to hot water with 1/2 cup of baking soda or soda crystals (no detergent)
and see if you get suds. If you do, you have build up. Too much detergent, and fabrics are not being rinsed well enough.
@stan
I will give it a try and see what the outcome is, we have relatively soft water here in our area and we are currently using half the recommended amount.
Will give it a go and see what the outcome is. Funny though, if the machine stands still for a while after the suds lock event and it abort the spin and we manually select a spin cycle there is non of the suds lock that we seem to get the usual excellent spin results.
Hopefully your advice will work.
Regards
Let us know Aldo
You can also run a empty load (no clothes no detergent) with hot water and just the soda crystals (washing soda) to help remove any detergent build up in the machine.
Same thing will happen if you have build up in machine (You’l see sudsing)
Bad washing habits...Not FS use
I use liquid FS sparingly and my machine is approaching 18 yrs old and smells super clean...what you would expect a washing machine to smell like.
I do have this routine where I do color loads first in which I use FS...but the last load I do whites with no FS..Just bleach / detergent and hot water...so I think that kind of washes anything that may have accumulated in the machine away. A few days later repeat...
Same here and what’s your opinion on only using 30 mL
(Two tablespoons ) of high efficiency detergent???
In my opinion, that’s way too little to clean anything, Plus has that we probably be something more for high sudsing detergent not hi efficiency detergent so it just kinda makes you wonder does this guy have a vendetta against all the big brands of detergent/softener
Excess fabric softener use
Can lead to some nasty build ups in machines if the clothes aren’t being washed properly in the first place.
It’s very important if you’re going to use fabric softener to always wash in hot or warm water and use plenty of detergent otherwise you’ll get a buildup of softener in the clothing and in the machine you have to wash it away each time you rewash clothing.
There is no such thing as detergent build up in clothing or in machines I have never seen it it is really impossible to have detergent buildup in clothing each time it’s washed.
It’s also impossible to have A buildup of detergent inside a machine detergent dissolves easily and simply rinses away you couldn’t get it to build up that’s just not gonna happen.
In general it’s better to air on the side if using more than less detergent more will never hurt anything unless you go to extremes.
John L
Preach it GE
Reply 14, I have actually seen detergent buildup in machines, but that’s only with front loaders only where the detergent drawer is, as they wouldn’t have been enough volume all the water wouldn’t be hot enough to very quickly dissolve it at low flow rates, it’s not the machines fault, it’s generally because the area would’ve had low water pressure or using a cheap detergent doesn’t health matters either, as from my previous workplace they always used to use really cheap detergent and I was the one who always had to deal with the tiny detergent cake that would always build up, so I started the trend of asking them and training new staff members to put it into the drum instead of in the detergent drawer, we used to use fabric softener then we went to nothing at all, and then I got them on the band wagon of using vinegar as a sour to counteract the cheap Alkaline detergent, I don’t know if they’re still doing it, if they are I’ll be impressed
Detergent can build up on fabric
It’s referred to as encrustation.
If you google “encrustation on fabric” you find explanations of how and why it happens.
If Laundress stops by, I’m sure shel be able to explain further.
STPP is one additive that helps prevent this.
Good rinsing and neutralizing of alkaline detergents is useful as well.
But..Overdosage of detergent on a load of laundry, improper wash temps, inadequate rinsing, and rinse temps then baked in with the dyer..Well there you go.
If this mistake is repeated with the same articles of clothing on next go around, reside will be reactivated and may get worse especially if the same mistake isn’t corrected.
I use to work in professional Dry Cleaning and Laundry.
It was common practice to use professional laundry sour in the first rinse
“first rinse being the operative words here” the laundry sour first to neutralize alkalinity, then a additional rinse.
Who ever was pressing shirts would be the first to know that the person running laundry that day had overdosed and or missed adding the sour. Fabric would immediately turn to a yellow or brown when iron heat came in contact. It would sometimes look scorched. This is a example of detergent build up or detergent reside. It meant everything in that load had to be soured and rinsed again. Often times in hot water.
Don’t get me wrong, I’m not advocating for under using detergent like whats being proposed by the dude in the Video.
I have to say, He did a good job getting the machine clean though!
