1966 Westinghouse range their first self cleaning oven
Thanks John & Eddie.
I was thinking an oven rack would have to be used as a broiler rack, and that the broiler pan would need to be placed on an additional rack under that.  Eddie's use of foil would certainly be a time saver for broiler/oven rack cleaning.
How strong are the stirrers?  They would be quite useful if they could handle a pot of risotto.
Oven control system
Hi Bob this Westinghouse use the king Sealy system same system that GE used in there first self cleaning oven’s not as bad as what Frigidaire used on their models at also had tender matic. When I found the stove 30 years ago and had a bad oven sensor same thing that used to go wrong with cheese was an easy fix.
Hi Ralph, this would not be good for stirring real heavy sauces I think it was intended for gravies and putting etc.
I’m making a huge pot of spaghetti sauce as we speak I don’t think it would’ve been good for this.
John L
Beautiful Range
You better be careful with this range around Kevin313. You might have it come up MIA!
Don't forget to spray the bottom of the foil covered broil pan top with nonstick, that makes it even easier to clean. I do that and you can spray the whole pan with hot water, then put it in the dishwasher. Saves fingertips with SOS pad!
Hugs,
David
love the stirrer...
Some science lab hot-plates had magnetic stirrers, the stirrer that you put into the flask or beaker looked like a big plastic medicine capsule and spun around as the matching magnet under the hot-plate surface rotated. This must be a pretty rare range I'd think!
Our neighbor in Towson was a Westy engineer and they had an early '60s Westy 40" range that was a nice one.
