Best dishwasher detergent/ additives for hard water?
dustin92
Jun 21, 2010
1,215
Jackson, MI
We have a mid 90's Kenmore Ultra wash dishwasher and very hard water, what is the best detergent to use and what additives? I have used Finish powerball tabs, and Finish Gelpacs, Cascade Actionpacs, Institutional formula Cascade (with bleach and phosphates). I have to use either Lemishine or Finish power up in every wash or the dishes are left filmy, crusty, and disgusting. The Finish Powerball tabs seem to be the best performing so far, with the Finish Gelpacs coming in second. Cleaning wise, the Cascade actionpacs were the best, but I bought the gain scent and after a few washes, the dishes started tasting like gain. Those are now sitting in the cupboard and will probably be thrown out. The institutional Cascade comes in last, leaving a nasty film on everything and doesnt clean very well. I want to find a detergent that will clean well and not leave filmy residue, and if an additive is needed, can you recommend something cheaper than lemishine? ($3.99 for a container that might last two weeks.) Thanks!
Institutional Cascade
Is good old fashioned chlorine bleach containing dishwasher detergent. While chlorine bleach and break down protein it is no match for modern enzymes.
The best solution for using an automatic dishwasher in very hard water conditions would be to install a mechanical water softener. Failing that there is the old standby of phosphates (STPP) added to the each of the wash and rinse water cycles.
Personally I'd go for the mechanical water softener as your laundry probably would benefit from being done in softer water as well.
We are planning on installing a water softener, all our neighbors have them, but the financial department is not going to allow that for a while.
What is your water heater temp set at?  You might need to turn up the heat so to speak.  How hard is your water?  Ours is medium hard here.
I use Bubble Bandit dishwasher detergent and it works great..It has close to 9% of Phosphates in it they list as commercial detergent so they can get away with it..I put one table spoon in the main wash and half that in the prewash and it works great.My dishes have that soft clean to them that I love...
I've been using Somat powder in my Miele lately. It's expensive, $20 for a 60 load bag, but worth it. You can order it from productswithstyle.com and get free shipping. Our water isn't quite as hard as yours in Jackson, but 30% PO4 in the formula works a treat!
I use Bubble Bandit dishwasher detergent....
Uh-oh
More dishwasher detergent to add to my stash, lol.
I have very hard water and recently purchased some institutional cascade. It's cleaning better (most notable on glasses) than the Finish Quantum tabs with a teaspoon of STPP added, but it's also leaving an annoying residue on the dishes.
I hope this is the cure all.
Thanks Wes!
I love the detergent and I use at both places the farm which has the best tasting water I have ever tasted but, it is very hard its almost like it is carbonated or something.I have L.G. dishwasher and barley scrape them let alone rinse anything.This is the best dishwasher
detergent I have ever used. I leave tons of food in the bottom and set it to normal wash and everything is perfect.I know everybody hates L.G. dishwasher's but mine has been great for me..
At our old house, the water was very soft, we used finish quantum tabs and nothing else. No lemishine, no rinse aid. We had a BOL GE dishwasher and it did fine. Here we have tried the finish quantum tabs, but like everything else, they leave the glasses and plastics filmy. At one point a few years ago (before we bought the house, but were here to visit) the dishwasher had stopped functioning completely from the scale buildup. The heating element was encrusted in about 1/4 inch of crud, the racks were crusty, and the whole interior was coated in crud. I remember hearing that it had started overflowing as well. (I think the water level cutoff was crusted too) At that point, the dishwasher was less than ten years old. I think they ended up soaking and running multiple washes with CLR. I cleaned the spray arms before it got to the end of the mess, the top spray arm was completely blocked, and the bottom one wouldnt spin because the buildup on the underside was dragging on the filter. It was always used with prewashed dishes and a heavy dose of Cascade gel. I actually got told off once for not using soap on the dishes before putting them in the dishwasher! Since we bought the house, I never pre rinse and it works fine.
This is the best dishwasher detergent I have ever used.
Whoo-hoo! I like the sound of that.
Gonna order some right meow.
Thanks again Wes!
Gotta tell you
After perusing this thread, I lucked up and sourced some commercial powder containing both phosphates and chlorine! It was amazing as it actually removed tomato stains on some plastic ware. I will be bringing my mother a jug of this. She is in Savannah where the water is hard as a rock and every time I talk to her she is telling me how poorly her KA tall tub is doing on dishes. She did notice improvement after using the Finish with power ball.
Thank you all for the insight!
I've switched to Cascade Complete w/Dawn pacs, which does a great job on pots/pans. It also doesn't discolor aluminum or leave that white powdery residue on plastics. They're a bit spendy, but I never need to use more than one in a cycle, even for really soiled pots/pans.
Finish Powerball Tabs were my former daily driver, but the Cascade Complete pacs do a better job on pots/pans, and doesn't leave residue on plastics. Highly recommended.
Remember that standard-issue Cascade Pacs are not the same as Cascade Complete pacs.[this post was last edited: 9/27/2012-19:45]
Wes-- I'm with you in praising LG dishwashers. I have the TOL from 2008 and it is the best dishwasher I've ever owned. LG dishwashers are notorious for having reliability problems, but mine has endured very heavy use without a problem (knock on wood!).
Our water here is rock-hard and we previously had to use Lemishine in every load of the KA to keep things from turning gray, and even then I don't think it was doing a very good job. When the KA to catch on fire and was replaced with a Bosch I made sure I got one with a built-in softener, and it has been nothing short of a miracle! EVERYTHING comes out perfect - glasses feel "smoother" than they did before, old items I thought were etched came out shiny as new...remarkable. I use the Finish Quantum Powerballs and nothing else now. I think I'm averaging 3-4 months per box of Somat salt (at probably 7-9 loads a week) which is pretty cheap.
Cascade Complete
I like this--we have been using this as our daily use detergent for a long time and have been pleased with it. I have not tried the Dawn version as we usually buy the Costco sized regular. Our daily driver is a Kenmore Elite machine purchased in 2001 and has been an awesome performer-- no complaints with this guy.
