Hey Gang
Hope everyone had a great Thanksgiving
Here's some pics of the 56 Unimatic set that I picked up in Michigan that Robert had posted for sale back in Sept.
Inside of the tub was covered in a film of hard water mineral/lime deposit.
You can see that the tub is all dull and rough
They must have some pretty hard water up there in Michigan
Had to scrub out the interior as well
As you can see the snubber plate also looks almost new
Still needs more cleaning though
At least the smell is gone
The set had to have some needed repairs by me.
First the timer would not advance.
There was a poor design flaw in the fill flume. They put the fill flume right next to the controls on the inside of the control panel with no barrier. When the washer fills the water tends to splash on the controls. On this washer you can see the hard water stains from the splashing water on the inside of the control panel and down the back of the washer. All the controls were hit by the water and rusty. Luckly only the timer was affected as all the other controls still work.
I was lucky enough to locate a timer and was able to replace it.
Here is a shot of the old rusty timer.
To fix the splashing water problem I went to the auto parts store and bought a hose to fit the fill nozzle.
I figured I really didn't need the screen in the fill flume so I removed it. I connected the hose to the fill nozzle and pushed it down the fill flume.
Works like a charm and no splashing
The next repair was the water valve--- it did'nt work at all.
Took it apart and soaked all the guts in vinegar overnight. Next day took a toothbrush to it, cleaned it up, put it back together and it worked like a charm.
Last repair ( at least I hope for awhile anyway) was the drain hose. It had the original Frigidaire drain hose with the brass threaded end. It was in too bad of a shape to save so I trashed it.
Went to Home Depot and pieced together a brass and PVC fitting that worked out well.
The dryer also has a couple of issues
One of the fan blades is bent or loose and hitting the side of the fan housing.
And just like the washer the timer is not advancing.
So I'll be busy with the dryer for a couple of days.
Hope I can locate a timer for the dryer like I did the washer.
Also hope to have first wash pics with the washer posted soon
So glad these machines got a good home! Congrats and enjoy your new machines!
Just curious where in heaven's name did you scare up that timer for the washer??
Jim congratulations!! I couldn't remember who had gotten this set. And thank you for alkl the great pictures. This is the only Unimatic year I've never seen up close and personal, either in my childhood or as an adult at washins. Bob
I found the timer at the parts store that Jimmy (filterflo) and I went to in Oct in Aliquippa, PA.
Jimmy posted the guy's name and telephone number.
You can find it in post #311789 on 10/27/08
Hey Jim, Im so proud of you and your great work. You are becoming the Unimatic expert......now having done 2 machines with wonderful results......Congrats on a job well done !
