Did you check the circuit breaker Dawnie?
A 220/240 volt circuit breaker is usually 2 110 volt switches that sometimes are connected together by a bar across the two switches so they act as one switch. Occasionally you will find a 220 volt circuit breaker where the two switches are NOT connected together. In a case like that the one that provides the current to the heating elements in the dryer may have tripped where as the one that controls the main motor, timer motor and drum light (if you dryer has one) may not have tripped and that would explain why your dryer still runs but does not heat. Check that first. If that is the case than you have to ask what caused the heating element to trip the circuit in the first place and go from there......PATRICK COFFEY
