Cold water washing has arrived
jetcone
May 2, 2001
7,678
Schenectady-Home of Calrods,Monitor Tops,Toroid Tr
Having developed my own detergent; Rosalie's Zero Suds; and always recommended hot or warm wash I was gobsmacked to try New Tide Professional.
The claim is professional stains gone in 1 wash in COLD.
Now normally I would brush this off, but I know P&G have been in the lab these last two years trying to build cold water surfactants and 3 of the chemicals I have been following along are now in this product.
Lets see what it can do shall we ??
I was pretty impressed
There was no grease on the kitchen towels all the hand grunge was gone on the bath towel.
Yes I said no grease ! That was one of the chemicals they were developing and I gotta say it works !
The towel came out as white as the 1957 Turnpike Cruiser !
Next I did a complete mixed load, jeans white items, black items. Everything came out great no dye transfer at all !
Yes those are tight whiteys with zero skid marks !!!
AND I like the scent its almost 60s ish !
What was the incoming temp of the water?
Will this still function well in warm and hot water temps or will the enzymes be destroyed?
I tried a small bottle of liquid Coldwater Tide about 10 years ago and got horrible results in warm (120F) and hot (160F) water temps. It did work fine in 85F though. An interesting experiment but I never purchased it again.
I am rather surprised that P&G put a significant amount of money and effort into a powdered detergent. I assumed it was on its way out and liquids would take over the throne for good.
Impressive results with Coldwater washing
But I’m gonna declare immediately that you cheated by using a lady Kenmore combination, washer dryer, arguably the best vintage washing machine ever made.
Get yourself an old Maytag top loader and then try this test, maybe Dan will do it for us.
John
John, you beat me to it. I too was going to mention the Kenmore Roto Spray washing action of the Kenmore Combination washer/dryer. Dirt doesn't stand a chance in that washer.
Also, try with Tide Ultra Oxi HE Powder.
Tide Professional and Tide "Pro-Line" have been flogging cold water washing for some time now.
Meant for commercial, institutional or OPL laundries idea is savings on energy and wear on textiles by using cold water but without sacrificing results. Latter is important for hospitality and catering linens where things are expected not just to be clean, but "pop" as part of presentation.
https://pgpro.com/en-us/brands/tide-professional/coldwater-laundry-detergent
https://pgpro.com/en-us/brands/tide-professional/tide-coldwater-system
https://www.americanhotel.com/pg-pr...ent-concentrate-closed-loop-15-gal-/p/1114779
P&G tests these versions of Tide in cold water temp of 90 degrees F. This would be between 35 to about hair under 40 degrees C.
There is an oxygen bleach version as well: https://www.amazon.ca/Tide-Professional-Powder-Detergent-Laundry/dp/B0839N3XB7
As an Amazon Associate we earn from qualifying purchases.
"I tried a small bottle of liquid Coldwater Tide about 10 years ago and got horrible results in warm (120F) and hot (160F) water temps. It did work fine in 85F though. An interesting experiment but I never purchased it again."
Also have a bottle of Tide "Coldwater" of old (Free and Clear).
Recall from reading in press and online P&G formulated Tide cold water versions to work best in just that, cold water temps of about 86F to 90F. Higher wash water temps actually decrease performance as enzymes and everything about said product was formulated for lower temperatures.
https://www.nytimes.com/2011/09/17/business/cold-water-detergents-get-a-chilly-reception.html
Those of us old enough to remember will recall laundry detergent packets advised using slightly more product when washing in cold water. P&G cracked that in as Tide Coldwater is slightly more concentrated than it's warmer water cousins.
Consumer Reports rated Tide CW highly at the time. But they also noted Tide "free and gentle" along with a few other versions worked equally well in warm water.
Since Tide CW is meant for 90 degrees or so F, difference between using warm water (100-105F) would be minimal in terms of energy use I shouldn't wonder.
In contrast Tide, Henkel, Unilever and others who sell detergents in Europe have products that work at 20 or 30 degrees C.
https://www.ariel.co.uk/en-gb/how-to-wash/how-to-do-laundry/cold-water-wash-guide
Japan of course in common with some other Asian nations is famous for doing laundry in largely cold water only. Things do come out of wash clean, but all over Japan and elsewhere there is a vast selection of disinfectants and other products designed to cope with foul smelling washing machines.
"I wonder how it will do when the water is 43-45 degrees during a typical Minnesota winter."
I don't think any detergent is going to provide even mediocre results at those temps. A tempering valve is your best friend in that situation, definitely worth the investment if one uses a front loader without a heater or just about any top loader.
According to the links that Launderess posted, "cold" water needs to be least 90F for this detergent to function properly. How many in the US are feeding 90F to their washer, either top or front load, for their cold water washes? Better yet, how many users are feeding at least 75F to their washer, which is the bare minimum requirement for most detergents to work correctly?
"Recall from reading in press and online P&G formulated Tide cold water versions to work best in just that, cold water temps of about 86F to 90F. Higher wash water temps actually decrease performance as enzymes and everything about said product was formulated for lower temperatures."
Yeah, got schooled with that one. Would have never expected worse results with hotter water but it indeed held true to its warnings.
That's pretty crazy results.... Remember the Cold Power detergent from a long time ago? Was that for cold water washing also? I'm imagining it was. I remember my grandma using it but she always washed almost everything in warm wash/cold rinse in her GM Frigidaire.
The water here is frigid in the winter too.. I wonder if my duet would mix with warm to give the cold a certain temp or if it just comes straight from the tap into the drum. Honestly, I have no clue.
P&G definitely probably has the most LAB testing hours over any other brand...
Isn't Tide one of the items on the list of items being stoplifted?
So based on the last sentence in Launderess's post above this one, in Japan, they get good cleaning results with this type of product, but poor sanitizing. Gross. My front loaders smell as fresh and clean as when they were new and so does the laundry coming out of them, but at least we know why there are so many ads for deodorizing clothes and washing machines. What a blessing to know how to do laundry properly.
Japanese laundry product market has detergents with both chlorine and oxygen bleaching systems. Latter is often "activated" just like Tide with Bleach or Persil. These products are designed to work in cold water.
https://lifeabroad.jp/html/daily_life/laundry.html
Indeed laundry product makers seemed to have cracked every niche of market.
"Attack Strong Deodorizer"
"Extra-strength deodorizing laundry detergent that removes urine odours (from bedding and clothing of children and adults experiencing incontinence) and other strong odours and stains. Also removes yellow stains. 2 rinses recommended. Safe for use on all machine-washable fabrics. Can also be used to wash the inside of your washing machine. Contains optical brighteners to make whites look whiter. Safe for use on fabric of all colours. Does not contain bleach."
Top loading washing machines of all sorts are popular in Japan and much if Asia. Problem is these machines don't have heaters and washers are plumbed to cold water connection only. There are ways around, but there you have it.
There are also detergents meant for laundry that is to be dried indoors.
http://www.survivingnjapan.com/2011/11/guide-to-laundry-detergent-in-japan.html
https://www.2hugeinjapan.com/doing-laundry-in-japan-part-1-laundry-products/
In Korea Clorox bleach is "LAX". It's no match however for often grotty washing machines fouled by cold water use only.
Tempering valves have been common on industrial/commercial washing machines going back to early part of prior century. Domestic washing machines had them early as 1940's or 1950's IIRC.
One would hope any washing machine worth its salt would have some way to temper cold water wash fills so things aren't what comes out of tap. Well at least for those who live in areas where tap water routinely drops to very low temps for good part of year.
In Germany and other parts of Europe "Cold and Short" has become new mantra on wash day.
"With regard to the washing temperature, the researchers found that the discoloration of the textiles increases between 20 and 40 degrees more than between 40 and 60 degrees. In some of the T-shirts examined, more than twice as much color was lost after 16 washes (85 minutes at 40 degrees) as with 16 short washes (30 minutes) at 25 degrees, as the researchers report in the journal "Dyes and Pigments". The loss of colour is therefore greater with cotton than with polyester."
https://www.chip.de/news/Schont-Wae...-kurz-und-kalt-waschen-sollten_179959911.html
P&G's Ariel wins high marks for washing in 20 degrees C water.
Bringing this back on home.
It may seem counter intuitive but powder detergents in many instances are better in cold water washing than liquids.
In Europe where laundry detergent powders are still common they best most liquid format products. Powders are simply better at whiteness, overall stain removal, keeping soils from redepositing on fabrics...
Tide "Professional" like TWB contains oxygen bleach and an activator.
https://pgpro.com/en-us/brands/tide-professional/powder-detergent#Ratings-Reviews
Over years makers of oxygen bleach activators in concert with detergent producers have upped their game. Original intent of oxygen bleach activators was to get boil wash results at warm to moderately hot wash temps (Dirt Says Hot, but Label Does Not...).
P&G and Henkel at least for their top shelf products have taken things down to "cold water" territory. This in keeping with push by governments and consumer groups for ever more energy savings on wash day.
Trend in Europe is clear; a study by Electrolux found 44% of European households doing wash at 30 degrees C or lower. If trend continues majority of households in Europe will be doing laundry in cold water.
https://www.electroluxgroup.com/en/...-to-30-wash-driving-down-co2-emissions-35393/
