Consumer Reports Detergents test
We get all our water from wells, around here. My water hardness averages about 400 parts-per-million, which is very hard---although not as hard as in some parts of Europe, which can top 1,000 ppm. Needless to say, I wouldn't want to be without a mechanical water softener.
I spend a fair amount of time in Seattle, and I think they have nice, naturally soft water; at least that's true for the neighborhood I stay in. It's soft, but not "mechanically-softened" soft, so soap rinses off easily in the shower, etc.
Sears Ultra Plus - Stain Fighting Formula
I picked up a box of 125 load Sears Ultra Plus in the green box which is 13 lbs, for $13.89 at Sears including tax. It only requires 1/2 scoop, so the box is actualy 250 loads for front load HE machines. Comes in at just under .18 cents per load, can't beat that! It seems to work great and I love the little bit of suds it does make in the Miele. Makes for a good wash viewing :) At the cost per load, this is a great buy. I would imagine the way I wash clothes this should last me at least 6 months!
Nice Miele, Andrew!
This is what is frustrating about Tide (perhaps Procter & Gamble detergents in general): The amount of suds in the wash portion of the cycle is similar to the photo above. The problems start in the rinses, which all seem to have as much suds as the wash cycle did.
I use SA8 for loads of bath towels. A scoop of that makes the usual amount of suds in the wash, but the third rinse is almost completely suds-free, even in my hyper-soft water. SA8 used to clean much better than it does now, so it is not my daily-driver detergent. I've gone back to liquid Tide With Bleach Alternative HE.
I think more people would be inclined to use Tide products---most of which clean very well---if they had cleaner-rinsing formulas.
Interesting!
Just finished up a bottle of Tide HE w/Colorclean and it was a very low sudser and clean rinser in the Calypso. Just cracked open the new pump bottle of Method HE and it makes no suds....even with an intentional overdose.
The water here is about 6-7 grains hard....so not too bad.
We have 9 grains in our water here, no water softener and we can't use Tide either because of sensitive skin and rinsing issues. Even if we use half of the recommended amount we still have suds in the final extra rinse.
We tried Cheer HE once, it left the clothes with a chemical smell. Peril, FOCA, and All work and rinse nicely. So that's what we have been using.
Tide HE powder does not suds up at all and rinses clean. The liquids I stay away from in my Miele since it and the drum design= causes suds to occur and the scolding of the oversuds light to be lit up. The above pic of the Miele shows suds but if it was Tide He liquid it would be another story..suds would be half way up the door.
Miele's HoneyComb drum has less holes in it and the wash action I find can create alot of suds. The drum also holds the water longer to create a skim layer of water to cushon the clothes and drive the water into the fabrics. Plus the HydroMatic wash action adds to the drama. Thats why in the pic above there is suds.
SUDS IN THE RINSE CYCLE
FL washers are suds making machines you can put clothes in with no detergent and see suds. The fact that you are seeing suds in the rinse cycle and not in the wash cycle doesn't mean that the clothes aren't being rinsed properly. Its because the suds suppressants that are in HE detergents rinse away and then you see a few suds in the rinses. But as long as the machine is going through the spin cycles properly with out suds locking a little foam in the rinses should be of no concern. In fact you don't want to over rinse with hard water you just end up harsh grey clothes as you deposit all the minerals from the hard water back into the clothes. But a lot of what you see depends on the type of washer you use. In my Calypso I can have 3" of suds in the wash and have nothing in the rinse cycle at all, although I will say the Calypso is about the best rinsing washer I have ever had. I always like to use the bleach test, when I can put a full dose of bleach in a wash load and not smell bleach when its done I think the machine is doing a good job rinsing. P S chlorine bleach will not hurt the aluminum spider in F L washers, in fact its very beneficial in keeping all the stuff from clinging to and growing on the spider and allowing the corrosion to set in and destroy it.
If liquid chlorine bleach is bad for front-loaders, my 8-year old Frigidaire should have been dead long ago. I wash at least 3-4 loads a week with a full dose of LCB.
The owner's manual for the brand new Frigidaires has for "regular" and "aggressive" washer-cleaning procedures.
The aggressive procedure (to be used when mold/bad smells are quite evident) includes using EIGHT CUPS of liquid chlorine bleach in the cleaning cycle. And it says the process may need to be repeated 2 or 3 times to tackle really bad mold problems.
All Oxi Active
I used it in a few loads was amazed. It removed more stains than my usual, All Small & Mighty with Snuggle. It produced little suds and it left a nice scent behind and blended well with Snuggle Green Burst.
Honeycomb drum - Thanks nmassman44. What is this wash action you mention?
Chlorine Bleach. I believe the manual for my machine says not to use it because the outter drum is stainless steel. No matter I don't seem to need it anyway.
38 gpg in ground water
I checked my city water report. They give a figure of 38 gpg (grains per gallon) for ground water and a figure for the Metropolitan Water District (that supplies much of Southern California) as 9 gpg. I believe our tap water is roughly half imported and half from wells, but I sent an e-mail to the water quality office asking them if they know what the gpg at the water tap is. The only figures listed for tap water were for toxic stuff like lead and copper.
Our city put in a groundwater recovery unit and in the winter (when no one irrigates) we are now an net EXPORTER of water, producing 1-2 million excess gallons per day and no imports. In summer, when irrigation increases, we are partly dependent on outside water sources rather than just wells.
