tomdawg
I have a friend of mine who is having issues with their DCS dish drawer. They start it, blue light turns on. drain pump starts and then it stops. Red light turns on.
They said it will only work if they pre fill the dishwasher with hot hot water before starting the dishwasher. Sometimes it takes a couple of times. Both dishwashers will do it, but mainly the top one does it.
I believe it’s about 4 years old and they run it probably 3 times a day. They are a busy family of 7.. well now it’s down to 5 as two of them moved out of the house. There’s no doubt it’s been through some west and tear.
They clean the filter out often
My thought is, the drain valve is probably clogged or built up with gunk/grease- the dishwasher initially drains to test the pump- if it doesn’t drain it turns off. I believe the hot water breaks down the gunk to clear it enough for it to work.
I’m not sure how the cycle sequence works- but I thought I’d ask.
I told them to get a dishwasher cleaner to see if that helps with getting rid of the gunk in the drain pipe.
