My Two Cents,
(For what they're worth)
A lot of people are nigh-unto criminally negligent when it comes to HVAC systems.
- Never changing and/or cleaning filters on a monthly basis (or up to three months with SOME filters)
- Never bothering to clean the condenser and evaporator coils
- Refrigerant charge (which can change quite quickly in a short period)
Just three that come to mind.
Dirty filters severely restricts airflow, and can result in abnormal system pressure, as can very dirty coils (which also decreases efficiency). A lot of people are scared of breaking something OR voiding the warranty with coil cleaning.
With systems using hot water or gas, I suppose checking the plumbing, pilot adjustment, burners, heat exchangers, valves, ventilation fans and so on is important
And with forced air systems, perhaps checking to ensure the dampers in the house are setup correctly, according to loading and system design and operation.
On heat-pumps, particularly, a biannual "service arrangement" is probably ideal, as you have a system that's running practically constantly through the year - so the coils are going to be accumulating dirt and muck. In some areas, you can plug a system pretty quickly with foliage, dust/dirt and so on (esp. with the aforementioned spine-fin coils).
What I mentioned above is the least of what I'd expect from a service arrangement. If not, I'd find another tech, IMO.
