Filter Flo Questions
Sorry to resurrect an old flame.
A while ago I adjusted my Filter Flo pressure switch to get it to fill on high to the proper level, and now it fills perfectly. The problem is, I don't remember which of the adjustments I played with.
Now I want to adjust the level of the mini basket fill, so I need to know which adjustment to turn as I don't want to mess up the high setting.
Attached is a picture of my pressure switch.
turn your water level switch....the one that DOESN'T move is for the mini basket...
you only need 7+/- gallons for the minibasket....anything more is just a waste...just enough to fill the basket, and keep the water flowing!
That's why I'm confused and why I'm posting... the screws do not move. The plate behind them does.
There is more movement behind the left hand screw (the one in the center of the switch) than the right hand one though.
I think it is the one on the left I need to adjust, as I think the one on the right is the one I adjusted the last time for the high water level setting, as I screwed it in several turns to get the level up to the correct setting, and you can see that one is screwed in further than the center one.
I just don't want to waste water trying to figure it out, and of course I just finished all of my laundry before deciding to adjust this!
yeah, my pressure switches don't look like that....
but I was going to say it looked like the screw on the left side had not been tampered with as the black wax was still intact, compared to the other one....
the worst case, is to back them both off, and start all over....and re-setting both at the same time....and label them for next time...
