aviator1974
Hello.
I have an Eaton's Viking 8 washer from 1989 (as close as I can tell), and an Eaton Viking dryer from 1990 (again, as close as I can tell).
These units seem to be private labeled Filter Flo units.
I took the top off the washing machine to repair rust, which unfortunately meant I had to remove the wiring.
When I installed the wiring, I second guessed myself and seem to have caused some problems.
The washer fills with water, but the timer does not run.
If I manually advance the timer I can get the machine to spin for a couple seconds, but i will not do anything else.
I bought the machines used and the schematics are missing.
Any help would be great as no one around here knows about these units.
