FilterFlo suds model
akronman
Bronze Member
Jul 20, 2010
2,260
Akron/Cleveland Ohio
Here's my recently acquired Model #WWA8355VCL GE Filter Flo from 1978, suds model. It sat for 34 years with that one rusted side exposed to the open laundry tub drain, other than that darn little rust. I bent the clutch solenoid back in shape to get 2 speeds, and now the machine's somewhat dissasembled for de-rust, etc.  I propped up the tranny assembly to keep it centered and keep strain off the huge rubber tub seal while I'm working on things.  The corner base plates and the rear edge/leg assembly all need sanding and painting.
IT worked well for me when first installed, just needed the clutch armature repaired and the suds valve(down the thread further.)
While it's getting a paint job, is there any oiling or lubing these need? Where the transmision shaft meets the belt pulley? The snubbers are alll dry and shiney where they rub, I believe they are meant to be grease free. All their attached rubber parts are intact, this is a quiet and smooth spinning machine.
A few drops of oil on the suspension pulleys near the top? Anything else?
clutch solenoid/armature
It was bent to hell, but I could hear the solenoid buzzing. After some pliers and bending, it's all back in shape and I tested it electrically, all is well. The motor is pretty shiny and dust free, are there any points to oil this?
suds valve
Here is the suds valve. The bottom port is incoming from the tub, top 2 are the outgoing drain hoses. It's just a duo of pinch valves, not rocket science. Other suds machines in earlier eras or other manufacturers probably did more, this one only operates in the regular wash cycle.  For returning the suds, you flip a switch to return, then set the timer at the SUDS labelled start of the regular cycle.  It isn't wired thru the water level valve or anything to finish filling the tub, it's just a dry agitate that pulls the water thru the correct valve. Then you stop the machine, put the clothes in, reset the suds switch to save or off, then it will fill the rest of the tub as needed and do a regular wash cycle.
It's plenty good enough for me.
missing parts
Picture is bad, but each side of the valve had 2 springs operating against the solenoid, 4 springs total. 1 on each side was missing, but available at Easy Appliances, about $20 total with shipping. Now the snap action is fast and tight, and the springs seal up the pinch valve fully.
valve
the above pic of the springs, and the overall inside peek into the metal box of this valve shows signs of ancient lithium grease to help everything move freely along those slots., I'll lube it a bit before re-installing.
Other than the one side of rust, there's just a few nicks.  Anyone with oil/lube advice while she's still on the side will be appreciated.
My other 78 FilterFlo, non suds model, has the ramped agitator. This one is 4 straght vanes, and I'll start an argument here but I can't see the difference. Both are great at turnover and agitation, I'll leave them both as is.
A little painting isn't bad for a machine that is almost 35 yr. old.
And it looks like your doing all the right things by supporting the suspension.
Can't wait to see it finished.  See if its the model I'm thinking of.  That is 3 toggle switches on the left.  2 knobs, mid-back console.
GE is fun to play with.  Uses a lot of water though.
I like those later 70s models.  And the straight-vane white agitator.
Your lucky.  Its going to be beautiful.
Are the drain hoses rubber or white ribbed plastic with an aluminum goose neck on the end?
I wouldn't worry about the GFI.  They are designed to be sensitive.  Good for you for using one!  I came close to getting a shock on appliances without a GFI.  This was years ago, once on a GE washer and another time on a portable Kenmore DW.  Both had been washed, but weren't completely dry, and apparently there was water in the timer.  I plugged the washer in to test , touched the chrome plated plastic knob to turn the dial and could feel a light tingle.   The DW I plugged in, and grabbed the laminate top to move it.  My finger brushed against the side panel and I could feel the tingling.  Thank-god they were grounded.   I quickly backed up, pulled the plug, calmed down, let my heart slow down as it felt like it was going to pop out of my chest- lesson learned.  1983 and I was like 14.
I was told by an electrician NOT to install a Garage door opener on a GFI plug because the sudden draw could trip the circuit and you'd be stuck outside.  So it happens.   They don't generally recommend installing a major appliance like this on a GFI circuit.  That is, something that you would need to count on if you aren't there to monitor it.  Things such as sump pumps, dishwashers, well pumps, furnaces, etc.
First "modern" GE I've seen with a suds. Like Kaiser Sozay (sp) heard of him/them but never seen. How cool. Seeing those giant drain & suds udders on the pump in your first pic just warm the heart on this cold windy day. It would be great to see the suds system in action, and a first, here, as far as I know for GE's.
Mark, I did a comparative, comprehensive test one afternoon using beach towels at various water levels, and though the action is clearly different, both the vane and the ramp were equally effective and thorough in their turnovers, even though I went in favoring the ramp. Eye-opening and humbling day it was. I agree with your view totally.
Drain Hoses
I'm curious to see the drain hoses of this machine. Since its from '78, does it use the ribbed white plastic or the black with the anti-kink coil around it?
One reason I ask is because of all the GE's I've seen, including the ones with a black rubber drain hose or a white ribbed plastic one, most used an aluminum or plastic gooseneck. On only one machine - that 1975 Dispensall of my neighbors that I loved so much - came equipped with a black rubber drain hose with the wire coil and a molded hook at the end. It was the only GE I ever saw with one. Now, looking at the parts reference page you had listed in your original posted article back in Nov, it illustrates the same molded rubber hose.
Did this machine come with the molded rubber hoses too? Anyone know why GE switched? Anyone have a machine with the molded rubber hoses? For some reason this has always fascinated and puzzled me and I've yet to see a GE drain hose with a molded rubber hook like the one on my friends Dispensall from 75.
Curiosity killed the cat...
Matthew
Drain hoses
Washer manufacturers started switching to corrugated plastic drain hoses in the 1970s because they were not only a little cheaper to make but mainly to reduce the cost of warranty calls related to kinked drain hoses which cost all major manufactures hundreds of thousands dollars in unnecessary warranty payouts every year. They did the same thing with built-in DW drain hoses for the same reason.
Overall I think that the smooth rubber drain hoses work a little better as the water flows through them more smoothly. It was interesting that special model machines continued to come with the rubber drain hoses such as Suds-Saver machines, commercial models and even when WP introduced the Resource-Saver washer it still came with the regular rubber drain hose [ I think that they knew that they worked better ].
hoses
This 78 suds model has black hoses with wire embedded/wrapped around. When it's back together--SOON--I will post more pics. My other GE FF, exact same model except 77 and non-suds, has the corrugated white plastic.
Dumb question here-----there's lots of stains on the cardboard/pressboard back of this machine. What's the cheap and easy way to paint it to cover up? I can't really clean it, just kinda cover over with paint, I think. What paint? Spray? Rollers?
Suds info
The machine is back together(98%) and runs wonderfully. I was right on the suds operation. To suck them back, you set the suds knob to return, it simply overrides the water level switch for the wash fill in the regular cycl;e, and you get whatever amount back that was in your laundry tub. IT doesn't stop to fill the rest, it doesn't stop to allow only medium level if desired, it just sucks all back in and runs right into an 18 minute wash. Pretty simple but damn good enough. Keep in mind there's no clothes in yet, you normally stand there and re-suck, stop the machine and add clothes, etc. So you can decide if it needs more water, etc. Simple operation, works well.
more
Someone was interested in the hoses----the main one with metal wire ribbing is the suds hose, comes out 2/3 up the machine.  Further down is the rinse drain/most draining hose. It was already customized by a previous owner, 3 feet added in. You can see the final portion in the lower left across the laundry tub, also metal ribbing. No leaks, so I will leave them alone.
There's various other machine's hoses and ground wires in the pic, an unholy mess fro sure.
Think you said earlier that the agitator works during the return as ususal. This would be a great time to switch back and forth between the ramp and the vane to enjoy the different styles in water chaos. Again, if you ever get a way to do it, what a treat a video of this would be. It's neat that you have the only later GE suds in the club because you like and use suds-returns so much.
Hey Mickey
I'll bum a friend's video recorder soon and see what I can do--
The ramp machine's agitator is easily removed, this one not so much yet, maybe I'll give it a shot. And I agree, if I can video both styles in the exact same machine, exact same clothing, maybe I'll change my mind.
I always chuckle at "suds return"... I suppose if I was organized to wash my bed linens first and THEN wash my work clothes (typically covered in dirt and stone dust), that would work... I'm sure I'd forget and do it backwards...
Hey Applianceguy47
You were right on the GFCI. This outlet is a quad box, GFCI on one side, a regular outlet on the other side controlled by the GFCI, nothing else at all on this circuit, just those 4 spots. I just rewired it so the GFCI controls itself only, the other regular outlet is non-gfci, and no more washer stopping at that one point. The rest of the entire basement is GFCI, I think local code needs all outlets in the basement GFCI'd except for refridgerators? But I ain't selling the house or getting inspected, I'll live. No other machines have ever tripped any GFCI's, just these 2 matching GE's at the exact same point in one cycle.
Also--anyone interested--I was wrong above, the SUDS return starts with a dry agitate at 18 minutes on regular cycle only, then around the 15 minute mark the water level switch and temp switch kick in to fill it to the top, then it does 15 minutes of wash. It will not stop sucking if you only wanted 1/3 tub or anything, but it does fill to the brim with chosen temp water. Pretty cool, and working perfectly.
Like the fair weather friend I am, this will be my completely favorite machine until I get some next one up and running, lol.
Must be a GE thing!
My 1949 GE fridge will trip any GFCI you plug it into. Not every time, but regularly, and always at startup.
Actually, compressor based products, such as refrigerators, ACs, dehumidifiers, etc. Surge much more when they start up.
For example: the first 1/2 second of a washer starting will surge 2 - 3 times the normal wattage. So a washer that uses 250 watts when operating will draw 750 watts its first 1/2 second of operation.
A compressor based appliance that uses 250 watts when operating, will surge at start up and require 6-7 times the amount of electricity. Approx. 1700 watts during the first 1/2 second of operation.
It doesn't seem like a big deal, but this sudden surge is what trips GFIs. This is why, the lights will often dim instantaneously when an appliance starts.
Also, if your looking to get off grid and use inverters to power your appliances, you need to do your calculations based on the MAX surge. Otherwise you will have problems with appliances not being able to start.
http://www.p3international.com/products/special/p4400/p4400-ce.html
the idiots who built my house had a GFI installed the alcove for the freezer.....all it took was for one power outtage, and I did not pay attention to when it came back on that the freezer was not "on" because of it tripping....2 days later I went to open the door, and was landslided by a freezer full of melted food all over the floor......
it has been changed to a regular outlet since then.......
not to mention, the "Low Temp" buzzer only works if the unit has power.....a good feature that is almost a waste......and they never thought of a battery backup for that!
live and learn
Phil
I did not have leaks, so I did not replace the valve/hose. If you are having trouble getting new ones, try here, maybe, Easy Appliance Parts, it's where I got the springs inside.  Even if the list says DISCONTINUED or NLA, just keep clicking thru to buy, there is some stock on some DISC/NLA items, at times.
The entire valve is made by Gorman-Rupp of Mansfield or Ashland Ohio, if that helps.
At the top of this thread is my washer model #<a name="start_44034.647196">WWA8355VCL</a>, maybe search for the suds parts on various parts websites using that?
By the way, what does your 3 hose valve do as opposed to my 2 way SUDS diverter?
http://www.easyapplianceparts.com/M...06099i06&Position=4&mfg=GE&Type=Washer&Mark=4
I have already called Easy Appliance Parts with your washer model number and the person who answered me didn't find the exact washer model number or the exact part... She sent me the link to fill valves and then she suggested that I call GE directly... As for the 3 hose diverter, I can't tell what it does, I haven't tried it yet! But it seems that many brands used the same valve as there are schematics for Speed Queen showing it on Sears Parts Direct (all with NLA parts of course) and other sites show Whirlpool and Maytag parts with the same number (the Whirlpool and Maytag washers I saw didn't have this kind of valve).
I tried to call again with the diagram in your link and they don't have the part in stock. (and of course, it's NLA). [this post was last edited: 1/10/2013-11:49]
