Response to neptunebob
Thank you for your input.
‘If the aluminum spider is such a problem, why don't the manufacturers just make it out of steel? Or even a sturdy plastic? Is there some reason why it has to be aluminum? Oh, I don't think plastic will cause problem with odor here because the spider is in motion would shed the moisture’
Good question, my opinion, the almighty dollar, it is the cheapest way to make anything that comes close to being ‘acceptable’ but, again in my opinion, fails miserably.
Although the spider is in motion this does not mean that it will automatically shed all the ‘water’ from all areas. It is my considered opinion that even at the fastest spin speeds in front load washers there are areas of the spider where the speed of rotation is insufficient to cause sufficient centrifugal force to be generated to ‘throw’ the ‘water’ off. These areas are the shaft and the hub of the spider. As an example, my Frigidaire built ‘Kenmore’ at approximately 1,000 rev/min has the outer rim of the inner drum traveling at approximately 60 miles/hour whereas, at the same rotational speed, the outer edge of the recesses in the spider hub are only travelling at approximately 6 miles/hour. You may have noticed a similar thing with the beaters on kitchen mixers, the ‘mix, sticks to the shaft but is thrown off the arms of the beaters.
‘If aluminum spiders are such a problem, I would think Alcoa research would have come up with a solution by now.’
Maybe they have but its implementation would almost certainly cost dollars and therefore cut into the bottom line or increase the cost of the appliance. Another detrimental effect of corrective action, in my opinion, and the bean counters really would not like this, it would reduce the number of overpriced spares ‘they’ could sell and also reduce the number of new machines required by the consumers as their older ones would last longer. ‘Got to create the market’.
‘Meanwhile, I am worried about something else that might grow mold. Today's airliners are made of aluminum and the air inside is dry to prevent corrosion. But the new Boeing 787 Dreamliner is made of "composite" (AKA Plastic) and Boeing claims that the air can be kept more humid and there is more pressure inside, which I guess helps people with respiratory problems. Are we going to see reports in the future about "moldliners"?’
On that one your guess is as good as, and likely better than, mine.
‘Oh, one other thing, isn't boric acid rather corrosive?’
My information, gleaned by perusing various MSDS’s for Boric Acid via internet searches is that in the case of very high concentrations its pH level will drop below 4.0 and it could therefore possibly be corrosive to some aluminium alloys. One MSDS at: -
http://www.jtbaker.com/msds/englishhtml/b3696.htm
notes that if water is present it can be corrosive to iron.
Hope this helps.
