cfz2882
anyone collect and reuse your washer drain water for lawn watering purposes?I have been doing it for a while with no ill effects:washers drain into a laundry tub equipped with a ball valve that can be closed to fill the tub-a haier countertop dishwasher pump works decent to pump water from basement tub to vortex type sprinklers as this type will not clog with lint particles.The haier pump is reversing type with separate drain section,so I had to disable and block the drain section.Very dirty drain water is ran down the drain with just the rinses recovered.
