The heat-pump in question works and defrosts just fine.
A friend's heat-pump has needed to use auxiliary electric resistance coils during the latest cold snap. Problem is they won't come on. He says the house went down to 50*F (10*C).
Now I am assuimng the thermostat is not defective, and that the wiring sends the signal to the air-handler just fine.
The circuit breaker (220 v via two @ 60a) is putting out power and there is indeed power (for the electric coils) in the air handler.
Both hot legs are active/hot (to ground) and to each other (i.e. the hot legs are indeed different "poles" => delivering the requisite 220v.)
So what's the problem?
Defective relay not allowing coil to be energized?
One-time thermal fuse, open?
Heat sequencer not cooperating? I see two of them rated at 5kw each. How do these work? Thermal trigger? Time trigger?
[These are intended to prevent the full load from coming on at one time, which would dip votage and brown-out lights, etc.
Any ideas as to how to "DIY" fix this is appreciated. Friend has that Italian disesase "Fundzarlo"! I'm gonna need to strap on my *COUGH* toolbelt and act like a man.
