Help! My Maytag 806 made the most horrible noise
WOOOOOO HOOOOOOOO!!!!
ALRIIIIIIIIIGHT!!!!!
i am so happy that you got your 806 back up & running. she looks beautiful in all her green & glowing glory!!!
YYYYYAAAAAAYYYYYY!!!!
:o)
so, how did you get your baby back up & running again?? did the guy come out to do the repairs or send someone else out in his place? or did you get someone else to help you??
enquiring minds want to know.....
Fixed but with questions please.
1. The locking lug is at the 6 o'clock position when the pulley is turned clockwise all the way to top where it can no longer move the pulley wheel. Is this correct ? (it is mentioned by someone the 6 o'clock position on the message board)
2. When the pulley is turned counter clockwise for the release the locking lug is now not quite at the nine o'clock positions as suggested, but at about 10 o'clock position, a little shy of the 1/4 inch to 3/8 that is recommend.
Is this what is causing the knocking noise I'm hearing mostly on heavier loads bing towels and rugs? BUT IT SEEMS IF THE 6 IS CORRECT AND IT DEFAULTS WHEN RELEASED TO The 10 O'CLOCK WHICH IS MORE IMPORTANT SETTING THE 9 OCLOCK POSITION WOULDN'T IT NOT STRT AT 6 OCLOCK? WHICH POSITION DO YOU SET FIRST FOR THEM BOTH TO END UP IN PROPER ALIGNMENT?
3. The Maytag washer to be used with the screw to attach the locking lug was $18 almost on the repair parts site. The first one that broke in half I don't think was this Maytag washer, but just a regular washer.
The repairman didn't have that specific part and had I ordered online to get ON TIME w shipping when I needed it would have been $ 40. Seems very expensive
The repairman used 2 regular washers. How Important is using the Maytag $18 washer that someone sent me the link to? I'm I okay with just using 2 regular washers> Has anyone done this instead of the Maytag part?
4. When you say the locking lug needs to be place rounded side down do you mean that it should be rounded side facing the floor?
The repairman came back to fix it. He did it for free as part of the 90 day warranty. He spent 90 minutes there.
The belts that he previously changed out are authorized Maytag belts. He said there was a little snag on the belt and he cleaned that off.
I showed him the diagram when he put the pulley back on leaving the distance .
So the washer is working again. I still have a knocking noise on heavy loads. Is this because the lug needs to be perfecto at the 9 o'clock position, but if the 6 position is there as stated should be when pulley has no give after benign turned all the way clockwise and it ends at under 1/4 ,
of an inch when it released how do you change that.?
But the knocking sound really is just on heavy loads.
The whining sound is still there when the spin throws the water for about 15 second.
I'm watching things closely. I am smelling a little rubber burning smell from the new belts. I didn't knot ice before.
But Im on the floor with my nose right up to the belts which I didn't do before. It's very faint smell, but is this natural to have this faint smell on new belts.
I think all of this started the knocking and squealing as stated above after he put the machine back together.
He didn't comment on that, but did get it back together and I showed him the diagram
Is the lock not being at 9 o'clock position the culprit? The spin actually seems to be quieter with the new belts and his current viit
Should I get the Maytag washer from the repair parts site for $18?
I explained the two noises didn't start until he changed out the old belts and seemed the pulley washing put back on and added lubrication to the brake .
He said it could be the brake assembly or a bearing issue. But why did they start after his initial visit?
It's a a 35 year old machine and everything works perfect with the exception of the 2 noises. Should I just live with it?
Thanks so much everyone!
I can't put anymore money into .
