Hoover A3110 Washing Machine Restoration 1980 Model...Part 2
chestermikeuk
May 29, 2001
7,432
Rainhill *Home of the RailwayTrials* Merseyside,UK
So after those scrummy cornish pasties its back to work, Timer - Check, Tub - Check, Motor - Check, now for the wheels, suspension, pump and back together!!
First up new wheels, which had flattened from sitting 30 odd years....We can now see the extent of the dripping water down the tub and onto the side chassis.
CLICK HERE FOR PART 1
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?51645_83~1
Hoover A3110 Washing Machine Restoration Part 2
Now for the new Anti-Twist suspension kit...the drum is mounted on steel rods connected with a rubber block and steel washers at the tub end and a nylon shroud at the baseplate, the large suspension spring is on the outside, a simple but very effective way of providing strong suspension - over the years they tend to twist with wear causing the drum to not be centred.
