Hotpoint Liberator Dryer 1701 re-build
hotpoint95622
Jul 27, 2008
1,315
Powys
Hi folks the panels are back from the powder coaters.
Link to the strip down thread
hotpoint95622
If you remember the heater plate has been damaged by the drum rubbing on poor bearings.
To strengthen the weak lower rim I soldered a steel band in place, worked a treat and the solder should not melt under normal conditions.
hotpoint95622
Fitted the wheels and feet to the base plate, I no it’s the wrong shade of blue, nothing I can do about it now.
hotpoint95622
Heater plate fitted, fixings from both sides, at this point I was at my whit’s end and the hammer almost came out.
hotpoint95622
Right the fun part, placed the dryer face down on some cardboard to protect the front panel. Insert the five bearing strips into the heater plate.
hotpoint95622
Remove all the base plate fixings so the sides splay out and drop the drum in.
Using your hand to slid the drum rim into the new bearings.
hotpoint95622
Tip the machine into it’s back, on the cardboard and fit the rear bearing plate, this pulls it all together.
