Is it me or are top load washing machines really bad a washing?
"Detergent Smell" Of European Products
That's tremendous isn't it?
I had my father send me some powdered fabric softer that is totally unscented to use on my clothes as I can't stand the majority of the "normal" softeners you find in shops!
I agree. The smell of modern detergents is so overpowering that it clashes with one's own deodorant and fragrance products. That can't be good.
Also, those long-lasting fabric conditioners (Lenor and Comfort): the stench seems to get impregnated into the plastic of the dispenser drawer, eventually leaving a sour, mildewy smell, that is very difficult to remove. Not nice at all.
I recently tried one of the pink Lenor products, not the Ruby one - my local Tesco got rid of that; this was a newer one. It smelled fine in the bottle, but on the clothes it was vile, a cheap floral fragrance. I couldn't stand it, so the bottle was tipped down the drain. I once did that to a bottle of Comfort blue conditioner too.
It does depend what you mean for TL'S.....machines with wash plate and weird like stuff, rollers etc are top loaders too but can't provide a good wash as Agitator type does.
Even some agitator type of new ones does not get clothes clean and does not work....clothes must be agitated and flushed in water to get clean, looks like for some modern manufacterers clothes must be just soaked to be clean, infact their washer do everyything but moving and flushing clothes properly.
I know aussie TL's especially simpsons, I know newer does have indexing tubs and long strokes, well, personally I find this thing a huge idiocy as with an indexing tub you just get your clothes spinning and not flushed and agitated properly, agitator back and forth action is vanished, with an indexing tub there's not water recirculation in the tub that you have with a normal one also, clothes are just moved ahead along with tub and then pushed again to agitator ramps..... and there's not even the amount of water recirculation going up.
Said this I think all depends from machines, you have maytag so it's very strange you're getting scum marks as they have a good rinse, scum marks happends with some crappy detergents reacting with liquid softener especially detergents with soap flakes or soap bars type of soap in, also some type of surfactans, this mostly happends where water pressure is so bad to reduce a good and effective spray rinse ,happened to me once using an italian detergent with soap flakes and liquid softener (I use it at times when I go out of dryer sheets), inlet screen got full as they fixed pipes around here, with the left out suds the softener reacts and during drain and or spin it deposits on clothes a thing that with FL's does not happend as clothes are not sink in "full" contact with water and most of times in many machines also constantly moved during drain till kicking into spin.
Living in Italy I've seen and I see many FL's, no one ever provided a good wash result as TL's does! Infact alot of italians who never knew agitator washers till last years are amazed from wash results you get with them and who can get one, are very expensive here, and are getting really famous even because are alot more energy efficient using hot water instead of a heater.
I've read a lot of trifles before, for example one is that washing with a Tl's you have to pretreat stuff! What? Never had any need to pretreat something with Tl's, a thing that rather with for FL's is the rule, as for prewashing heavy soiled stuff, I let you imagine what you'd get loading muddy stuff in a FL that use less water than a TL,if someone claim you need to prewash with TL I can't imagine with a FL!
At my seaside house we have a FL and I have not only to pretreat but prewash and soak night long stained laundry by hand, infact I can tell you that is a "normal" and a "everyday" practice at least for the people I know here in Italy to pretreat and prewash by hand heavy soiled and stained stuff, before washing everyone I know who use FL's do a meticolous search even just for that pasta sauce stain there could be somewhere and pretreat it.
Things that for me are absolutely unusual and not normal!
Another thing:
TL's are "hard" on fabrics not at all, is actually the same thing of a hand washing!
I agree anyway with the fact Fl's have a genteler "action",no that being washed with an harder action like agitators matters something anyway in terms of wearing clothes as someone claim also, but of course FL's are gentler! They does not even move clothes! Just tumble wrapped, packed laundry and balls of laundry down splashing into few inches water, and this would be washing? At least older ones used more water, now just few inches!
The only thing that goes near a wash for me is when you load them with very few items, clothes at least in this occasion drop and are flushed just a little bit in water, but most part of them drop in water vertically and are not even flushed.
I think the most effective wash action of FL's I've seen (just on video though) is the Westinghouse Laundromat washer and the English Hoover (maybe Keymatic?), because of water amount used and oblique drum, but anyway I think are not even nearly comparable to TL agitator ones!
But as someone already said, we could go ahead forever with this topic.......
The only thing that leaves me a little upset is that often people who talks, I bet my nuts, have not even ever seen and or tried a FL or a TL one! You can understand this from the speeches they does!
But anyway:
About scum marks just try not using liquid softener or a different kind of detergent.
Sometime depending on the type of washer fabric softner and
well my toughts on this is that sometime detergent and fabric softner do not mix well take for a exemple a topload washer with an agitator that as a fabric softner on top of the agitator they sometime dump the liquid fabric softner while the washer is still in its first spin so that do not leave much fabric softner when the washer starts to fill for the rinse compared to frontload washers where the fabric softner is dump in the rinse at the right time and do not forget that older 1970 and earlier washer had auto dispensers like for exemple the inglis royal washer that was posted as pod and certain kenmore washers had auto dispensers and they did not have mounted fabric softner on top of there agitators.
Pierre,
Just as an FYI,
Laundry Detergent and Bleach neutralize each other. A lot of top loaders have a bleach cup which dumps the bleach into the outer tub so that it doesn't get directly ontop of the clothing.
Unfortunately, while I have found it to be effective at bleaching clothing, it isn't as great at washing them, so I usually have to select a second rinse and put the bleach in on the first rinse manually or I just have to run another wash.
It's really nice to have a seperate dispenser I can just dump everything in, then just start the machine and walk away.
First of all, there shouldn't be any detergent residue for fabric softener to mix with if the was was rinsed properly before the addtion of the product.
The "scum" persons are reporting on laundry when using fabric softener is likely the same as it was back in the days when soap was mainly used for laundry; a mixture of unremoved soils/oils/ detergent residue combining with the fats and oils used in the fabric softener.
Another problem could very well be the fabric softener was not properly diluted and or used in water so cold it never would.
In the old days when soap was the main "detergent" housewives/laundresses would see "streaks" of soap residue on laundry as it came out of the wringers.  Again this was from the things being improperly rinsed and the "scum" in the wash tubs was still clinging to the fabric.
When using top loading and or the Hoover TT washing machine one never stops rinsing until the surface of the water is *clean*. If a visable film of whatever is on top of the rinse water then the wash still has some sort of residue (detergent and or incomplete soil removal) and either requires another wash or rinse.
