Direct Drive V Belt
I can see absolutely no advantage to direct drive, The way LG and other companies go on about it you would think they had invented the wheel.
The technology used on the motor I can date back to the early 1970s.
10 year warranty on the motor, so there should be as there is bugger all to it, if the seal fails and the bearings go this is likely to take out the stator coils on the motor which of course will not then be replaced under warranty.
All the LGs that came into work had shot bearings, lots of gizmos and styling touches but when you look inside them, just the usual mediocre build quality like every other similar priced machine
Washing quilts
As I have an old fashioned small capacity high water level machine I have no need of jets and umpteen wash action etc.
So when it comes to washing quilts I have two summer quilts that I clip together in the winter, I can wash one of these at a time in my machine on a 60o cottons wash, it takes 1 hour 15 minutes and because of the high water levels it is washed and rinsed perfectly.
I had to stop using feather pillows, so these synthetic filled ones are a doddle to wash as aswell, I put two in around the walls of the tub and use a 40o delicates wash which is a very high (half way up the door) water level
Pets Wash
We have a large selection of towels and sweat shirts that the cats (3) sleep on, they are washed on a 60o cottons and I have never had a problem of fur build up in the machine, there is some times a little hair left on them so I can put them in the dryer on no heat and any hair gets blown onto the filter
So much emphasis is placed on features now days yet very little is spoken about how well the machine is made or its life expectancy.
From what I can gather it SQ score highly on build quality and longevity so they would be who I would go for, little point in buying a glitter box if that's all it turns out to be in the long run
That's my thoughts
Gary
Ps I remember in an old Hoover vacuum cleaner book it showed a pillow being puffed up with the air from the cleaner, it involved undoing a few stitches so you could get the nozzle end inside the pillow and switching on, oh and of course using the Blow facility
