Is this a 90s Maytag DC variant?
db130
Active member
Jan 23, 2016
37
Boston Metrowest (MA)
It's not too far from me and and the washer itself appears to be already outside and not in the basement (which I consider to be a good thing so that I don't have to haul it out of the basement).
But... the seller might be a bit on the hillbilly side because when I asked for the model number, he replied with, "it's a maytag."
Once Runematic mentioned Performa, I used the custom Google Search option on this website and came across a previous discussion:
Looks very similar to a LAT2500AAE? If that's the case, it looks like a decent washer with:
*Infinite Water Level
Mini
Small
Large
Oversize
Reset
*Second Rinse ON/OFF
*Wash/Rinse Temp
Hot/Cold
Warm/Warm
Warm/Cold
Cold/Cold
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?58923
It's a true Maytag if it has the porcelain tub.  I had a secretary who bought one of these as it was one of the last of the true Maytags.  If it's a plast4ic tub, it's a NorgeTag.
Louis,
Those were sold in Holland? That might explain the odd configuration.
I've never seen one. I've seen Neptunes, Atlantis, then Maytag closed up shop.
A few of the family are in the blue cheese business up in Newton Iowa.
Vacerator
This is most definitely a Dependable Care washer with the Performa name on it, like I said before.  I sold many of these washers new & used.    They had this washer out at the same time as the Norgetag Performa and the control panels had the same stripes on them.  I know the difference between the two platforms, believe me.    Oh, and the Norgetag Performas weren't built in Searcy.
This SAV washer was made in Searcy after Maytag bought Amana.  The Norgetag's were made in Herrin, IL and some Atlantis (also a Norgetag) were made in Newton.  Maytag management was not making wise decisions buying these other companies and taking their designs and integrating them into a "Maytag" washer.
