Just got my first wringer washer, and it needs a little work so I need some help
Now the motor is out and has been taken apart and put back together! I replaced the cord, gave it a ground wire, measured to make sure the ground works, cleaned out the dust bunnies, grease the unused end of the shaft, brake cleaned the outside of the motor, and inside of the end caps of the shell as it was a bit greasy, and same with the motor mount pieces.
I plugged it in and tested it, and it works great! Thank goodness! I was pretty worried tbh. Haha! Now on to the Power Unit!
I believe the oil on the wringer post leg is from that crossbar that connects to it that catches all of the breather hole's drippings. That crossbar is filled with oil! Though I am sure my other gaskets arent in great shape.
Whoo Hoo
I'm so glad the bolts came out.
Now the lovely job of cleaning everything, and paint.
You have quite a weekend ahead of you.
I have another suggestion.
Adjust the height of the machine before you get it reassembled.
I'm sure your going to clean the wheels,
Tipping the machine backwards cause whitey to start dripping. just a few drops. But I panicked
anyway. Nothing has come of it and she stopped dripping.
But I will not tip one over again.
Have fun and keep us posted.
Me too! And oh yeah! Though I will have other things mixed in so I am not sure how much I will get done this weekend, but at least cleaning the power unit out.
And oh, how come? Why adjust the height? And yeah I will be cleaning the wheels.
The machine can be tipped over frontwards without it spilling oil. Also I am taking all the oil out anyway so if I have to tip it backwards, I could.
Thank you!
You want the wringer to be at a safe comfortable height to use it. Pinkies to tall for me (all 4ft 10in.of me)
Whitey we lowered, wringer is about chest height. Just right.
I feel like I'm lifting fabric over my head when I use pinky, she's about 3-4 inches taller.
So I use whitey.
The top of tub is just about hip height.
Blankets are heavy to wrangle out of the tub. So are wet sheets.
Also there are horror stories of females getting their upper girly parts caught in the wringer.
I have hair down to my rear end so I have to watch out for that too.
Using a wringer can be a real work out. I usually do 6 loads when she gets rolled out.
I split laundry between a portable 1.6 for daily wear and the wringer for towles, blankets
sheets. Items I want washed in hot hot water. And I rinse in a large tote, with vinager and cool water wring back onto the top of the washer lid.
I also have a laundry spin drier. . To remove the extra water from the wrung items. As they are to wet to put in the dryer.
Using this method I can easily do all 6 loads in 1.5 hrs.
When you are doing laundry with a wringer that is all you do is laundry. Wash. wring, rinse, wring.
Average wash time per load is approx. 5 min. For normaly soiled clothes. Then rinse and wring
You will also want to get a floating lint catcher sold on amazon or ebay. But that's down the road.
Have fun.
Oh I think I should be alright with the height then, since I am 6'1", and no girls will be using my washer, and it will take years for me to grow my hair that long haha! I would have to experience using it though to tell for sure what height I like.
The portable washer idea is cool! Those are interesting. For me, there is already a regular washer inside that I can use if I dont feel like going out and using this one, but after all this work, it is going to be my daily driver. I want a spin drier to do the same thing! But I want an old one, not one of those expensive new ones made in china.
Also, I plan on rinsing in the washtub the same as washing. And I plan to add a little bit of citric acid powder to that, to neutralize the very alkaline powder soap I will be using in the water that goes outside, as it is near a ditch that goes to a waterway. Vinegar could probably work just as well.
And do I need to catch lint? I have never used an automatic washer with one. An interedting idea though.
Lint filter and spin dryer
On e-bay shipped from US.
China is cheaper
And I got a mega spinner from Laundry alternitive.
The designer is a member here. It is made in Brazil.
I works really great. Super simple no timer close the 2 lids and it starts open lids and it stops.
It says up to 20 lbs wet. I don't push it so I put in maybe 10 to 12 lbs.
You can hang clothes and they are dry inside in about 2 hrs.
http://https//www.ebay.com/itm/US-W...hash=item3f91bd1697:m:mhGu4K-BTeVXCSzik6eu0YQ
Hmm interesting. I dont know if I am worried about lint or not. I do feel like maybe an auto removes more lint because of all the holes and the spinning with water.
And I have read some not so great reviews of the Laundry Alternative's spinners. How is the quality on them? Is the basket plastic or metal? And do you like it a lot? I am hoping to find a vintage one because I love vintage stuff, and it would be more solid and cheaper. Can you fit a big blanket in yours? I can never tell how much they would really fit by the pictures.
Spinners
The mega is a durable plastic outside. And inside. So no rusting. And yes the older laundry alt. spinners were POS.
But this one seems quite durable. And I've used it since Christmas with no problems.
20lbs wet is what is listed as the max weight. I know of one other member here that has one and reports were all good. And if you have an issue you call the number and get to talk to the engineer not a coustomer service nit wit.
I have not found a vintage one and looked for a very long time. There are vintage Twin tub machines.
However they are to large for my area. And parts well really hard to find.
There was one ( spinner) listed on shoppers spree. I think this week. Not vintage. and as I recall metal.
Hmm thank you! I will look more inte the L.A. ones. Did they imptove on them? And that is cool you can talk to the actual engineer! I do still hope to find an old one. And yeah I don't want a twin tub lol. Too much stuff I wont use.
How in TF
How the heck do you get the power unit out? I got the shifter rod disconnected, all 3 bolts out of the horizontal drive, and that bottom bolt mostly out. The bottom bolt just keeps turning and has the braces pushed away from the PU. The horizontal drive also will not separate from the PU, even with a chisel.
I will keep trying.
I cannot get them out. Tried hammering, PB blaster, more hammering, i cant grab them with vice grips, I dont think I can reach them to cut a slot in them, I dont have a torch to heat them up, and the teeth are stripped. I want a screw extractor set. Maybe that will work.
