tinkr
Possible source for parts. And my 2 cents worthof experience
I have read here on the forum that Lehman carries parts for wringer washers, although it is not listed in their store inventory. I called the phone number and she said they did (at that time)
This is the Amish store Stan was referring to.
https://www.lehmans.com/?partner_id...MIyKD5hOCC2gIVR5N-Ch1miAvTEAAYASAAEgLshPD_BwE
Also on Ebay there is a complete power unit ( gear box) Pricey at 170.00 with free shipping https://www.ebay.com/itm/Vintage-Ma...534534?hash=item1ca5403bc6:g:I0cAAOSwx2hasH3d
We restored a pink E2lp. And I was lucky to find (on ebay) a gearbox with plate as the one listed above.
At that time Phil had the index listed. And I bought the gasket for the gear box to center plate.
Large circular rubber gasket, And the rubber seal for the spline (tub seal) and small ring gasket that keeps the gryator from floating.
We made the other gaskets with material from auto parts store.
Removing the gulmite bolts is a PIA. we ended up cutting them off. And in removing the threaded part of the bolts, stripped the threaded holes in the top of the gear box. Yea a real bummer,
Gulmite wrenches.
Phil had one listed in june 2017 42.50 that did not sell. He may still have it.
I fear the seal from spline (tub) to gearbox has failed if you have water going up to the weep hole......
Phil has that seal listed on ebay now.
While searching for parts, another wringer was on craigs list. 50.00.
Call him and I explained how to start it and
and get the wringer to work. He was nice enough to see if it worked. It did and does.
Now I have 2. ( I am so fortunate)
With the knowledge you have now, a donor machine may be the ticket.
But still need the special wrench to get the
bolts off.
Daves repair is not in business, but here is link to his page that shows you what the wrench is and size of bolts required.
We got standard bolts with washers when we put pinkie back together.
http://www.davesrepair.com/Parts/MYT-38518-Gulmite-Wrench.htmI
I know there are wiser than I here on the forum. That may give you better advice.
Good luck.
can't beat a wringer for cleaning and getting laundry done fast.
Here's a pic of Her royal Highness. MISS PINKIE.
I figure her total cost was around 250.00 with parts and purchase.
Labor HA HA cant' put a price on that as
many many many hours spent on this project.
But I have a machine that will be running long after I'm gone.
Gulmite wrenches.
bolts off.
Good luck.
