Wringer safety bar is not working correctly...unless I am misssing something. When I hit it, it only separates the rollers just enough to let a sliver of light through, ans pulling them apart does not separate them. So not only does the wringer swing around and try to eat fingers, but it also will not release them with the safety bar lol!
The lever does lock and unlock the wringer though.
I am pretty sure the rollers are good. Have not inspected closely for cracks but I will. There are no flat spots though.
Wringer swings
Wringer does go in forward and reverse, but sometimes you have to wait a minute at first and move the lever a bit.
Agitator comes off shaft, and does not float. The agitator also has holes in it so it may never float, unless bakelite floats. Good idea to get a new seal in case, I may.
Tub is completely solid with no holes. Thankful to not have had to deal with what Larry did.
Agitator runs smoothly, though it does move a little while disengaged which could maybe be from old clumpy oil or the collar?
Spline seal is trashed
I got new hose at home depot that has the exact same inner and outer diameter, so that is good
Motor works well but maybe could use a little lubrication
Cord is trashed
The wheels! I did not think of that! They looked pretty messed up to me, cracked up rubber, but ill look again.
Will be getting a new pump and rubber wheel
I looked and looked for junk yards when I was searching for a machine, but all I could find were auto graveyards and metal scrapping places. Also the machine is too much trouble to remove and put back in the building it is in. I think I will just destroy those bolts.
And I was wondering about parts in the PU and on the agitator shaft that may need replacing, like the bearings and the collar on the shaft?
