surgilator1
the next time you steam clean your carpets; instead of using the reccomended cleaning solution try using 1 cup of rubbing alcohol with the hottest water possible in your tank. if you like to keep your water heater on a lower setting to conserve; just crank it up on high the night before so it will be readily available while cleaning. i'm just speachless with the results i achieved on my white wall to wall carpet in my home. threw away a new bottle of bissell solution and didnt even blink an eye!(p.s. my water heater was set at its highest temp setting. steven
