KitchenAid that wont fit
acelondon
Member
Feb 2, 2008
18
Hi everyone! I finally found myself a nice retro dishwasher on weels (kitchenAid year unknow)
It look's great BUT i've got one problem whit it... The pipe end won't fit on any tap.
Does anyone know if i can bye a adapter somewhere or if i have to change the whole end of the dishwasher pipe?
here see what i'm talking about :-)
cause frankly, i'wouldn't know what answer to give you, this pictures will speak in my stead.
Let me see the kitchen faucet. I bet I know what's wrong, you don't have the proeprr aerator on the end of your faucet to connect into your coupler. It's like the "male" part of the equation. That's part of the parts which come with a new portable appliance like a dishwasher or washer.
ah a uni-coupler.
The needed adapter is avaialable at your local hardware store. Look for a quick-connect coupler for DW-ers.
IIRC there are three styles. One is way off from what you'll need and other other two have a long and a short aerator.
Also unscrew your present aerator to see if the threads are inside or outside the tip of the the water spout. Some adapters come with a second piece that allows you to use them with either inside or outside threads.
one of those is bound to fit!
If you look at the inside of the water inlet hose-coupler (top one) there is probably a little prong that is intended to hold up a metal "plate" within the bottom of the aerator(the part connected to the faucet). This allows the water out of the faucet quicker and un-aerated.
Toggles is right, of course
I have the exact same model dishwasher, and it also came without the faucet attachment.
However I was able to pick one up at a local Orchard Supply Hardware store for less than $10, as I recall. There are a couple of types, and as I recally you will want the larger type. You might want to take careful measurements of the female connector on the end of the hoses so that it matches up with the male connector you need to put on the faucet.
Thank's everyone you all are very help full.
therefore, i have another chalenge for you all and also a question...
first the question:
Can I use cold water with my dishwasher or is it warm or hot water only?
And now the chalenge:
You see the picture, how can I restore this part of my aquisition?
I like your drinking birds on the shelf.Is that a built in Kitchen Aid dishwasher in the bakground?Just wondering why you would want to wash your dishes in cold water?To get to the bottom rack of your dishwasher do you have to lift the top rack out or do parts of the rack flip back?
Nice Machine.
I have the Original Owner's Manual. The Bottom Rack is turned around. The Silverware basket should be in the back of the machine. But that's not important. You would only use a hot wash. The machine runs through a hot water purge to heat up the Cast Iron Parts for about 1 minute. I'll attach some pics of the top rack in the load position.
Cycles...
The machine is pretty quick. 1.5 Start Warm up "Purge",7 minute Wash,1 minute drain, 2 minute Rinse and one more 1 minute Rinse.Drying time is 24 minutes. It uses about 9 gallons of water total. 43 minutes Total Time for the Cycle. My scanner is not working but I'll post some pages of the Owner's Manual when it's up. The detergent dispensor holds 1 full Tablespoon of detergent. Just throw it in the bottom of the machine at the front. This will prevent it from getting flushed out near the fill port at the back of the machine.
Your built in kitchen Aid is very sharp looking. Is it very old?
And what about the birds? Are they vintage too?
When I was little my neighbour had them. Just loved them. She used to make them drink beer.
Great memories for a 6 year old kid.
