Let's meat Sylvia...
Literature says the following for BOTH models.
This appliance is not designed for use in America. Only for countries that use 220 / 240 V electrical outlets.
Luigi, that which you found reminds me of the Amana & SQ models with the booster heater before they discontinued the models.
We have them here as well, though I never saw them in any laundromat. Our local laundromat does have Huebsch stacked dryers but Miele washers.
Dryer
Galvanized drum?!? My aunt's BOL HOH had a galvanized drum. I guess if it is a thick enough coating like commercial dryers have, or like the coating on the perforated Hamilton drums that seems to last almost forever, it would be OK and allow them to use a heavier gauge of steel than some modern brands use in their stainless steel drums.
Eco Dry
If you are using the dryer in a heated or cooled space, you have to remember that every minute it is operating, it is pumping 150 or more cubic feet of inside air to the outside. This is air that you have paid to heat or cool and replacement air is being sucked into the space from outside. Lengthening the drying is economical at times of the year when the inside air is not being heated or cooled or if the dryer is in an unheated or uncooled space like a garage, basement or outside utility room. It is economical to not use more heat than is needed for the task, but many factors other than the amount of heat used by the dryer need to be factored into the savings picture.
EcoDry
Per the instruction manual, the first heating period reaches the normal target temp, then it's reduced by 10% for the remainder of the cycle ... so for example, if the normal High temp is 150°F, it heats to 150°F then reduces to 135°F.
eBay
I suspect we will start to see online retailers pushing these machines before they are actually on the showroom floors. Keep an eye on eBay and Amazon...
Malcolm
New model numbers ???
I found these model numbers which fit the scheme for the new models listed in the videos posted above. Does anyone know what these different models might be?
Frontload Washers AFNE8RSP113TW01
Frontload Washers AFNE9RSP113TW01
Frontload Washers AFNE9BSP113TN01
Frontload Washers AFNE9BSP113TW01
Frontload Washers AFNE8FSP113TW01
Single Dryers ADEE8RGS173TW01
Single Dryers ADEE9RGS173TW01
Single Dryers ADEE9BGS173TW01
Single Dryers ADEE8FGW173TW01
Single Dryers ADEE8RGW173TW01
Single Dryers ADEE9BSS173TN01
Single Dryers ADGE8RGS113TW01
Single Dryers ADGE9RGS113TW01
Single Dryers ADGE9BGS113TW01
Single Dryers ADGE9BSS113TN01
Single Dryers ADGE8FGW113TW01
