jbrady3324
Member
Mark and Decoy
@mark - I made half turn adjustments at a time. After each adjustment, I ran a test cycle (towels) to see how much additional water was in the drum. This isn’t full proof as the water level will be higher with clothes in the drum but gives you a good starting point. I then left the top off and ran some cycles with clothes in it and adjustment further from there. What I did not account for was more water in the Rinse cycles so I ended up turning the screw back a bit.
@decoy - Do you think the water level slightly above the door gasket is okay? I also noticed the water temperature dropping about 3-5 degrees Celsius since making the water level adjustment. Have you noticed the same thing? I may dial it back a bit more to see if that raises the water temperature
