Hydraulic Assist . . .
Oh, how I hate spongy vacuum boosted brakes! Through the years Lincoln has occasionally used a hydraulic assist, as have some other companies. Lincoln also used a hydraulic wiper motor for years in the '60s, again driven off the power steering pump. One interesting factoid about Lincoln brakes is that they briefly offered a primitive anti-lock system on the rear brakes only of the Mark III in about '71. I think it was the first anti-lock system outside of the pioneering Jensen FF of 1966, which of course had full four wheel anti-lock courtesy of the Ferguson four wheel drive system and Dunop Maxaret brake controller. I don't know much about the Mark III anti-lock, as almost nobody bought it and it wasn't offered for long. About the same time Buick briefly offered a simple traction control device for the Riviera, but again it wasn't promoted and didn't last long. Two sad examples of Ford and GM actually offering some advanced safety technology only to cheap out when they couldn't turn an immediate profit on it. Ultimately others (can you say Bosch?) spent the time and money to develop the concepts into really useful products.
Hydraulic assist doesn't necessarily provide better brakes, just better feel in my opinion. Alfa Romeo in particular has a history of providing spongy, over-boosted assist but excellent brakes so the cars stop very well but to me feel nasty. I always hated that on my Alfetta coupe. The reason for the superiority of hydraulic assist is simple: vacuum boosters use air as their fluid, and air can compress and expand, while hydraulic fluid by its' very nature doesn't compress and therefore provides better feel.
My favorite power brake design of all is the traditional Citroen system, which is true power and not power assist. It uses no master cylinder, but rather a proportioning valve which distributes brake fluid at high pressure to the front and rear brakes when you push the pedal. The actual amount of fluid is determined by both how hard you push the pedal and the relative loading of the front and rear suspension . . . more weight in the rear means more power to the rear brakes. The high pressure fluid (approximately 2000 psi) is provided by the engine driven high-pressure pump and accumulator system, so the pedal feel is always nice and firm and travel is very short, maybe 1/2" or so, giving reduced reaction times.
