Looking for GE WH23X42 pump
jdm
Member
Sep 3, 2025
11
I need a pump for a GE washer that has started to leak a lot. The part number is WH23X42, and it is a 4-port pump with a metal cap on the top. I have been having trouble finding one that is reasonably priced. Any sources for these would be appreciated!
Looking at the longer term, can this pump be rebuilt? If anyone has done so, I would be interested in what replacement parts such as seals were used and where they could be obtained.
Thanks for any information!
Not sure what pump you’re looking for. Do you have a picture of it? There are no GE pumps that have a metal cap on the top that I’ve seen.
What’s the model number of the machine or a picture or how old is the machine that you need to pump for?
It appears to be a FilterFlo 4-port pump. The referenced metal cap presumably is the pulley to which the flex coupler attaches.
GEAppliances.com Pump WH23X42
Signed: Goofy Glenn
    29.9 KB
The model number is WWA8858MALWH, serial number LF195336G. I think the WH at the end of the model number is for white machine color. The picture by DADoES is correct, and yes, the metal cap is where the flexible coupling connects.
Can someone explain why this pump has 4 ports? There is one source for the water (the tub) and one destination (the drain hose), which would only need 2 ports to connect. One thing I had looked at a bit was getting a combination motor/pump like https://www.ebay.com/itm/286693900470 as a replacement, but aside from the work involved in retrofitting, these pumps quite reasonably have only 2 ports.
For the benefit of anyone finding this thread in the future, it turned out that eBay was the best source for the pump. However, there have not been a lot of sellers there, so with them it is hit or miss on finding the pump at a good price. When I started this thread, the only options there were very expensive. Fortunately, a more economical alternative appeared later. The completed listings at eBay show a wide range of purchase prices.
I had also tried searching for online appliance parts sellers and checking their inventory if one were given or calling them otherwise. Maybe a dozen calls did not turn up a pump. However, it seems that the eBay seller who sold me the pump was one of the places I had found with my search for online sellers, and the inventory there simply showed that the part was no longer available. So calling instead of relying on the information on a web page may be the best route to finding the part.
One of the people I talked to said that the pump was used from 1979 until 1985, which may help date a washing machine having this pump at least a little bit, assuming the dates given are accurate.
Could have let me know that you found a pump. Learn some manners!!!!
What on earth are you talking about? I waited a week for you to give me your name and e-mail address so that I could send you payment and a shipping label. I sent you messages stating that I needed that information, and I got no reply. You told me that you would be shipping the pump last Saturday.
jdm
New member​
Joined2025-09-03Messages4
2025-09-11
Is either USPS or UPS OK for you, or just USPS? I checked USPS rates on their website, and the price was $10.05. So Pirate Ship is a bit over half the cost.
I will send a payment through PayPal in the amount of $50 since I am paying for shipping directly. I will need your name and an e-mail address for using PayPal and sending the label.
Quote Reply
Report
jdm
New member​
2025-09-12
I noticed that I also need to know the date that you will be shipping the package. The Pirate Ship website requests that information as part of the process of making a shipping label. I am not sure why, and I doubt if shipping a day or two later would make any difference.
Quote Reply
Report
coldspot66
Well-known member​
Silver Member
Joined2003-01-08Messages1,552LocationPlymouth, Mass
2025-09-12
Saturday 9/13/25.
Like Quote Reply
Report
jdm
New member​
2025-09-12
OK on the date, but I still need your name and an e-mail address to send the money through PayPal and make the label for shipping.
Quote Reply
Report
jdm
New member​
Tuesday at 10:53 AM
I never received your name or e-mail address. Have you decided that you do not want to sell the pump? You had told me that you would be shipping it last Saturday.
I ended up paying a little more on eBay, but not that much, and I am actually getting a pump instead of wasting my time sending messages to someone lacking the courtesy to even reply. When you tell someone to learn some manners, you should be looking into a mirror.
Hi JDM, glad you got a water pump.
For the record that same pump is used from 1961 through 1995 on GE filter flow washers the same pump fit every filter flow model, the only exception was they made a very few basic models that did not have the lint filter feature, and had only two ports on the pump.
This two port pump was the same pump that was used on the General Electric combination washer dryer from 1963 through 1973
It’s hard to believe that these parts are drying up, but because this pump fits so many different year machines I can’t imagine it’ll be impossible to find a water pump anytime in the next decades.
John L
Does anyone know how the metal cap is attached to the shaft? The new pump works perfectly. However, given that they are obsolete parts, I would be interested in seeing if the old one might be repaired, and getting that cap off is the first step to getting at the leaking seal.
Its NOT a cap, there is no such thing on a GE pump. First of all you are looking at the pump upside down. What you are incorrectly calling a "cap" is the coupling for the flexible drive. It is PERMANANTLY attached and NOT removable. There would be no reason to ever remove it as those GE pumps are not rebuildable AND since in my 50+yrs of appliance repair I have never seen one of those couplings go bad.
I am aware that the metal cap is part of the flexible coupling, but alone is not the coupling. I am also aware that this cap is at the bottom of the pump when it is installed above the motor. I also know that these pumps are not usually rebuilt, but I would like to see if they can be.
The cap is in good condition. However, it is in the way if I want to get access to the seal. It is clear that the shaft and the cap are two distinct pieces. My question is how the two were joined. Knowing that would give me the best chance of separating them nondestructively.
For the benefit of anyone interested, the cap on the pump was pressed on. After soaking it in penetrating oil, I tried using a bearing separator to hold it while trying to separate it from the shaft with a hammer and punch. Unfortunately, the cap broke around the shaft. As shown in the pictures, there is a fairly thick hub in the center of the cap around the shaft. An approach that might have been successful would have been to drill holes in the top of the cap and then to try removing it with a small 2-jaw or 3-jaw puller attached to the bottom of the hub. Alternatively, with some care, the cap can be ground away without doing much, if any, damage to the shaft. The cap could be replaced by a pulley with the groove filled in with RTV.
The plastic cover below the metal cap was easily cut off with a narrow saw so that it could have been attached again with screws. In fact, I have seen some versions of the pump that use screws to attach this cover. It appears that the plastic cover is designed to divert a small amount of water that may leak under normal conditions.
With the metal cap and plastic cover removed, the seal can be seen. It does not appear to be a typical seal, and I did not see a good way to remove it. So my rebuilding effort ended there.
The pictures I tried attaching did not get included. I got a message that "A server error occurred. Please try again later." If there is a trick to including pictures, please let me know.
Hi everyone!
As my Electric Machines professor used to say: "those two things didn't born together". I'd always thought that with the correct tool, technique, time and patience the Filter-Flo pump shaft and coupling can be disassembled and the seal and sleeve could be modified and improved.
I have many original damaged pumps to try different techniques. Maybe I can make some tools that can be used like a puller. All I'm missing is time...
There apparently are some issues with the board software after an update that occurred on 9/27/2025. No acknowledgement from admin/tech as-yet but reports of problems have been posted so presumably they're aware.
Hi everyone!
Besides trying a 2-jaw or 3-jaw puller, it may be possible to drill and tap holes into the hub and then use a puller like a smaller version of https://www.aliexpress.us/item/3256808439562096.html to pull the cap off. The diameter of the hub is about 3 times that of the shaft. The bearing on the pump can be definitiely improved since it looks like there is only a bronze bushing. I was not able to see what, if any, actual seal is used under the bushing. As I had mentioned before, I did not see a good way to take apart that part of the pump.
GE filter flow washer pumps
The part that is being called a cap is really the drive hub it’s press fit onto the shaft. It was not designed to ever be removed nor would there be any reason to remove it.
The early versions of this pump were screwed together. They were first metal and then they were turned to black baklit plastic and later went to polypropylene plastic. These pumps could be disassembled from the top, but you were never able to replace bearings or seals in them.
The drive hub is a pressfit item that could be pressed on and off, but you wouldn’t be able to press it on again without destroying the seal in the bearing
John L
