Maytag A712 & DE 712
gadgetgary
Jan 31, 2005
3,867
Bristol,CT
They arrived safely yesterday. Toggles and I found that these machines were originally in Iowa, then moved to Texas. From there they went to Ohio, and then to Connecticut. There are in great shape for being moved so much. We cleanded them up nicely and proceeded to do 4 loads of laundry in them.
Dryer Control Dial
Steve and I were a bit confused and thought that the timer on the dryer was not working properly. We were going to order another timer until we read the manual that stated that even if you set the dryer for Timed Dry(ex. 40 min), the pointer would move to the end, but continue till the clothes were dry. So what is the point of having timed dry? Guess the Electronic Dry controls were on every cycle.
We turned the pointer thru the cycles and it would not shut off. We thought the dark markings were the shut-off points to each cycle.
My Plug Queen
created an outlet to convert a 220 dryer to 110.
We did a load of PANK jersey knit sheets in the A 712 and dried them in the DE712 on 110V. They took a long time to dry, but, came out perfectly.
We took off the back panel to find exactly where that ding-d
The Steve version?
I'm assuing the dryer temp buttons are air, delicate, and regular. The other two buttons are press care on and press care off.
How dry I am...how wet I'll be, if I don't find the
Gary wanted to see the ding-dong. I pretty much know what the different versins look like, and how they work at this point. :-)
The temperatures are exactly as you stated.
The other buttons are actually "Dry" and "More dry."
The more I see what these Maytag (And Kitchen Aid, too) beauties are all about, the angrier I get with Whirlpool for killing their engineering.
