westytoploader
- Joined
- Sep 4, 2004
- Messages
- 4,485
Hey guys,
I just came back up from the Studio working on the AMP with my 1965 Repair-Master. I removed the cabinet & front panel, was able to access the damper assembly. I found the stop bolt and collar opening, and removed the stop bolt. I then turned the tub to access the T-key in the collar. After pulling it out, I inspected it for any signs of wear--looked fine to me at least. Now, my question is...how are you supposed to re-install it, and what could be the cause of the no-spin situation?? Every method I tried led to the collar not lowering properly, which in turn will not allow me to get the stop bolt in. I'm thinking that perhaps the T-key wasn't installed right to begin with.
Upon further examination of the hole in the spin tube, both from the machine and from the diagram in the repair manual, there is a long slot beneath that (making said opening "lollipop-shaped"), apparently to let the T-key/collar slide down to drive the spin tub. The opening in the collar into which the T-key is supposed to fit isn't wide enough to accomodate the T-key in a vertical position to let it slide down in the slot, even though it appears to illustrate it in the diagram. The spin tube and collar aren't misaligned either...am I missing something here??
If anyone has a solution I would REALLY appreciate it!
--Austin
--Austin
