I agree that this Maytag mvwp575gw is not made as well as the old models were and do not think it is a true commercial quality for that reason.  I would be curious how the machine referred to was used and what/how much detergent, bleach, etc. were used for the loads.  Honestly, the only issues like this (extremely short life and major failures) I have seen have been reported by a few on this board.
I agree that this Maytag mvwp575gw design is not as made as well as Maytag’s older models, but no manufacturer models are.  Speed Queen comes the closest to their old models with its TC5, but even it has two control boards.
There are some issues here that need to be resolved.  One is these ridiculous DOE requirements.  At least this model still clean clothes and I can get around the one real quirk, which is no tap hot for the ONLY smaller load cycle.   Not having tap hot available for the loads that require it in any model means more chemicals have to be used to achieve a similar result.   There also needs to be an auto level water that works or a water level selector added to this model.  MORE water is used at time instead of less because of this oversight. The ATC is a gimmick (just adjust your faucets if needed) and so are those control boards to satisfy these new regulations.  It is also annoying for the tub to fill by switching back and forth from hot to cold.  The only reason they do this is because of that unnecessary ATC sensor.  Control boards and sensors cost more money so they had to find another way to cut costs because many consumers cannot or are not willing to pay $1K for a washer.  I do think the cheaper build quality is more of trying to sell to the uneducated masses who would rather pay less initially.  I don’t necessarily think it’s great for our environment to have to buy two or three washers for about the same price as one, but it is what it is.
I personally would have preferred the TC5 for the main cycles being available as half loads, no ATC, and tap hot for all of those cycles.  It wasn’t available when I made my choice, and the price for that model ranges from $1K to about $1400 from the places I can get it from.  Also, I don’t think the extra price for the matching dryer is justified.  If the TR series is the only model that is available again later when I have to make my choice, I still will NOT buy it.  I would rather have clean clothes and replace the washer more often because that is the choice *I* will have for the types of laundry I do.
However, I do think I will get at least ten years out of this Maytag model when properly used for residential use (although that will probably include a few minor repairs).  I think I would get 15 to 20 years out of the TC5 IF the bearings last that long.  I’ve said this many times.  Consumers do not have access to the parts for cost and often cannot do the repairs themselves.  Part of the “disposable” appliances is because of what repair people charge to fix them.  Some also got this washer while they had the ten year parts and labor guarantee, but the consumer purchasing this model today only gets a three-year warranty.
This Maytag comes with a five year parts and labor warranty and has upgraded parts compared to their commercial technology line.  This is a lot cheaper and more convenient than going to the laundry mat.  In my opinion, it is still the overall best cleaning washer and the second best overall washer.  If you don’t want or need the included warranty and use it properly, I think the Roper and Amana models with a dual action agitator would work well too.   My advice to others is take the time to get your information from several sources and make the best decision based on your needs.  Unfortunately, budget and availability will be a factor too.
