volsboy1
I can very easy tell that disposer was ran a lot by how worn the shredder ring is..
Maytag disposers never used reversing motors they all turn clockwise if you look closely you can see the how one side is worn down bad
compared to the others...
That reminds me Wastekings did have cooling fans cast into the rotors.I know I have took enough apart I know not much of a cooling fan but better
than none like on all I.S.E. machines...
Maytag used G.E. motors in them and had some problems with the starting caps..I have had to replace two of them in two machines that were
very old..The disposer will start with a bad cap but it draws a ton of current and can fry the start windings..
If the cap is bulging that means its bad..Don't ever touch a cap unless you discharge it by grounding out the terminals with a screw driver..
Capacitors can hold a charge for a very long time and have killed people.. So be careful..
