**Special Thanks again to yogitunes!~**
He was kind enough to send me the propane conversion kit for one of my Neptune Gas dryers. I will start out with the Older one first so I can pair it with the Atlantis washer. They look so alike!
Here is a picture of the gas valve. Not sure what to replace, but what's the worst that can happen, right?
Your question about switching out the agitators? The answer is no Someone else had ask me that some years ago but the agitator shaft in the Atlantis is way too short.
Sper32, Damn it!!!!
Jetcone, Love that windowed door. How much for just the door?
seems the only other one I have seen is the commercial laundry dryer. Great mod, now let me have it!...and your little dog too!!
...Does anyone know where I can find a programing guide to the Neptune Commercial Front Loader, Model MAH21PRDWW.
All I am able to find is the installation and salesman's cheat sheets in PDF* format.
I need to get the user guide to get it into service mode.
Thanks!
Thanks!
I found the manual, but it isn't clear on how to get into diagnostic mode for my model. It says insert key and unlock, now in programming mode? Except there is no card reader or coin box on this model and It never turns off if you leave it plugged in...flashes "select cycle". It would be nice to lengthen the wash cycle and add the optional extra rinse to all the cycles.
OK. I found out how to do it. It was in *STD* mode and all the cycles were exactly 37 minutes long. It even goes as far as being able to set the fill temps and tumble times.
So you made that yogi?, very nice. Very inspirational, I thought it was a salesman's tool like those clear front dishwashers or washer lids you see in some of the collections here. But I guess where there's a way, there's a window! Thanks
