moffat cooker
Moffat Rotisserie Parts
Like all the photos from that 60's brochure, my mom's oven has that same rotisserie as pictured here. But it came with another part that we cannot identify a use for. It's length fits perfectly between the assembled brackets that holds the spit rod (the spit rod is much longer of course) and this "mystery" piece has ends that bend down 90 degrees from the flat bar, and then out at 90 degrees again for about 1/2 inch. Can't find anything on what that part does.
I know that if you sort of "lock" it under the brackets in a criss-cross fashion you can use it to lift the hot drip pan/rotisserie bracxket set off the oven rack once it's pulled forward - but is that what it's for?
Also what are all the other "sundry" holes punched into the drip pan for (and, no, I do not refer to the insert piece that let's juices drain)? the user manual is not very helpful.
Geoff
1978/79 Moffat Cooker
Hi - so glad to find this site! Hopefully I can get some assistance :-)
We have a Moffat double-oven cooker with eye-level grill + rotisserie with white ceramic hob.
The Model number plate has 'disappeared'- I think it was on the back of the housing, we've looked all over it and cannot find it anywhere and the Manual has also gone. Over the last couple of years the ceramic hob elements have been fading and we'd like to get them replaced... because we don't have the Model No. we cannot order them.
Does anyone recognise this model and can provide a Model number. Fingers crossed.
Just to say - having now thoroughly read the posts, our oven is very similar to the one in the photo from Peter in Post No. 10 - but has a small oven and a large oven with a non-usable(!) 'storage' space at the bottom.
