More Woes With Whirlpool 6620 Front-loading Washer: 2nd Machine Also A Dud
because when I went to their website recently and looked at the FL washers, I saw 3, the stainless model said "With Sanitize".....so I just now went back and I noticed they all say "with sanitize" and I never noticed that they all stated that the when I looked at them the other day. So NOW I'm thinking maybe they don't have heaters and that's just a built in cycle that sanitizes without a heater if you use Oxy or something like that? I got my hopes up (LOL)
Who is this Hugo?
I went back to his channel just now, he has a TON of videos. Using Whirlpool search of his videos, I scrolled and scrolled and mostly I came up with 7 year old videos. Can someone link the actual videos you're talking about. I want to check them out. I can't find them. Thanks.
Hugo Fiori is from Brazil, IIRC. You have to search for Brastemp as that's the name Whirlpool uses over there. Just look at his uploads: he only recently uploaded a set of videos about the washer in question.
How does a machine (washer/dishwasher) sanitize without a heater?
It sounds like a sneaky way to make people think it has a heater, when really it doesn't and it's the OXY that would do the sanitizing. Although I'm not sure WHY they would need a cycle when you could just ADD OXY to a cycle but there may be more to the OXY cycle. Maybe it needs a certain amount of time.
It seems like I remember someone said their sanitize with Oxy cycle used a LOT more water than other cycles. This was a while back. I think it was a FL whirlpool maybe 5 years ago or more.
Sanitize (reduce germs/pathogens to an acceptably-safe level
 True, but how effective is oxy at reducing germs/pathogens in lower temperatures without a heater?
"Sanitize" is getting thrown around too loosely these days. Modern dishwashers that contain a sanitizing cycle don't even get up to 120F. That's false advertisement IMO.
um
sanitize cycle on some dishwashers is 120? Seriously? Damn.
Anyway - I misread and forgot that Sanitize with Oxy meant no heater. I just quickly looked on the SQ website and saw "sanitize, so I figured they had a heater. I see now they don't.
anyway - about the Sanitize with Oxy cycle: What does it do that's so special if the Oxy is what's sanitizing? What is it about the Cycle that's supposedly special?
I'm guessing the main wash cycle is stretched out longer. That helps out but it doesn't begin to replace the effectiveness of higher water temperatures that only a heater brings unless one has their water heater cranked up to at least 160F with a short run to the washer.
Mark, the SQ Sanitize with Oxi main wash cycle is an hour long. You have to use default settings and put the oxi powder in the tub before laundry. the rinses are described as a special santize rinse. The final spin period is like 12 or more minutes, longer than any other of the SQ final spin cycles.
It's amazing
Youtube is full of all kinds of washer videos (more than you could watch in a lifetime probably) and I don't see a single video of someone doing a "sanitize with Oxy" cycle. LOL
Not directly related ... my AquaSmarts have separate Allergy and Hygiene cycles.  Hygiene does not reference "oxy" or chlorine bleach.
Allergy says "A hot wash with extra rinses to target dust mites and remove detergent residue."
Hygiene is "A hot wash for times of illness or infection. Dry clothes in sunlight or on hottest dryer setting."
I haven't investigated which parts of the fill and wash process are tap-hot (Eco Active, HE level, and deep fill level if it's involved).
The AeroSmart dryer has an Allergy cycle which probably runs high temp and maximum dryness level, possibly with some extra heat time after max dryness is sensed.  "Kills off dust mites and removes wastes. Also good in times of illness. Not recommended for heat sensitive items."
My Intuitive Eco agitator model has an Allergy cycle, which I know for sure is tap-Hot Eco Active and Warm/Hot (122°F ATC) deep-fill.
