e2l-arry
RE-ASSEMBLY
Started this afternoon. The leg extensions and casters went back on first. Really easy when you can position the washer in any position without worry of an oil spill! Then I re-attached the horizontal and vertical drive. I added about 4 oz. of grease. That looked to be just about the right amount for the space available. Then you re-attach it in the machine, the same way the Service Manual suggests to remove it. And it DID!
The E Bay power unit is at a UPS facility about 20 miles from here so I expect that tomorrow. And the stuff from Dave, pump hardware, 8' drain hose and tub will be here by Friday! I think the hose is just a hose so check out the cool goose neck that I found at the Hardware store at lunch today. It fits the current drain just right! I'll just attach to the hose with a clamp.
