New Platform GE TL Washers
These new design machines have been used in their 24" & 27" TL stack machines for at least 3 years now, and we are seeing problems with main seal leaks it destroys the bearings right away.
It is an almost impossible machine to take apart and fix when this happens due to corrosion at the tub mounting area, we fixed just two of these machines, now they all get condemned. Even a $1500.00 stack is not worth fixing. Over the last year we condemned at last two dozen of these stacks, we always advise the customer to get in touch with GE and in almost every case GE has replaced the entire machine at either no cost or sometimes at about 1/2 cost. [ they know that they have a BIG problem with these washers ] GE has also been supplying the entire suspended washer assemblies for these machines to their techs to make the repair possible in the field, but we have been unable to get these washer assemblies so we just have to condemn the entire machine.
Two weeks ago we ran into a customer that had the KM 27" stack version that was less than 3 years old with the leaking bad seal noisy bearing problem, and he had tried to get Sears to do something about it and they would not give him any help, so we installed a new 27" stack WP TT.
The full sized WP TTs easily last 18-30 years before you have serious repairs on them, the only thing better in a full size stack is the SQ FL stacks.
Keep in mind that NO TOP LOAD GE WASHER built sinse 1995 is easily repairable when it has main seal, top bearing, transmission, brake assembly failures on models that have brakes, 98% of these machines hit the scrap pile when they have problems in these areas.
Whirlpool built machines on the other hand are easy to repair when they have similar problems, the VMW machines can be a little expensive to fix but you replace the entire transmission-bearing and seal assembly in less than an hour without killing yourself.
The big exception to this is WPs 24&22" World Washers are not worth fixing when they have seal and bearing failures, these are just as bad as GE machines.
John L.
