New Electrolux Laundry
Opinions vary greatly about everything. Too bad some people have no tact at expressing their's. I have had an LG made front loader and dryer for over 2 years now and it is the very best set of machines I have EVER had. And I have had and used about EVERY kind of washer and dryer ever made including speed queen.
When you work for Electrolux you can also brag about the newest and best washer there is. Try getting parts for your LG and Samsung washers, there are many who are still waiting. They are disposable appliances, exactly. Whirlpool on the other hand cares about longevity.
Frigidaire front-load washers, made by Electrolux, are at the bottom of the list for reliability according to CR. I traded out my 2010 TOL Frigidaire set for Maytag 8100's (made by Whirlpool). The Maytags are unquestionably the better machines.
Technical Literature
I'd love to see the technical operation literature on the Electrolux. I hate that some of these newer machines don't perform as expected with options deliberately mislabelled but do something completely different...
Malcolm
The only documentation I have is the parts breakdown of the 617, showing each parts location. The longevity comment on Whirlpool applies to parts availability, not life of the machine.
There are some reports that customers are in true belief their machine is not working out of the box. It takes almost 5 minutes for the 617 model to mix the detergent with water before it is dispensed into the drum. It truly is an effective way of stain removal and a more thorough clean.
True sanitary washes are done using Heavy Duty or Whitest Whites, also the new series offers better rinsing. Many improvements under the hood in the new series vs the old.
As mentioned before, they are the US version of the ÖkoMix models sold by AEG over here. The idea seems verry good, but one thing perplexes me: AEG is known for its long cycle times over here. 2:40h usualy. And the ÖkoMix system premixes detergent and water, so the cycle time should be shorter due to faster soaking and activation of the detergent.
However, all machines equipped with that system have normal Cotton cycles that take at least 3:30h, usualy even more. These are times that are normal for the Eco cycles, but not the Normal cycles. So, that would be a deal breaker for most, if they'd know before buying.
From the video, it looks like this Electrolux washer does not have a sealed tub, but a split one (see from 0:25 to 0:30 and also 0:39 to 0:42). Does this suggest that the split tub is making a comeback on some Electrolux machines now? (Or is that just what Electrolux wants us to believe? ;))
Not entirely sure how much it differs from my current Electrolux. The machine would fill with a bit of water, start the recirc pump and continue filling.
Guessing it's just a marketing trick..
Major improvement I'm looking out for is the ATC.
Figured out that on warm setting, it would fill with hot water and then add enough cold to bring down the temperature to desired level.
Not a problem with some fabrics, but would want to wash darks assured they won't be saturated with 120F water and concentrated detergent first, then brought down to 90F.
Worst, same protocol applies to the delicate cycle.
Action gentle enough for a woolen sweater (on cold) - but anything that could benefit from a warm wash is going to be tumbled in hot first.
Only way to have your clothes never touch hot water is either:
Setting the machine to the "stain treat" cycle, which is a profile wash - but can't be selected on most cycles that feature gentler treatment; or
Setting to "max fill" empty, then cancelling, adding clothes, re-selecting the cycle with "max fill off". Works for small loads only though; subsequent fills due to fabric saturation will result in intermittent sprays of hot and cold water - and most of it is directed through the basket flume - right on the load.
Good Pricing
Over the Holiday weekend, I ventured into my local big box store. The Elux-617 pair were stickered $748 each in that granite/black color. Pedestals were 225 ea.
I would have pulled the trigger on the spot if the checkout line was more than an hour deep. I had other places to be and couldn't wait.
Malcolm
Keith from Roseville,
your early post war kitchen is in fine condition for it's age of roughly 1944-'45.
That's when the GI house I grew up in was built. A one and a half story bungalow also?
Saw them in Sears today.,,
Beautiful looking machines. Why are they made in Mexico???
Mike
re; the factory
is in Mejico (Mexico) because it costs a fraction to assemble them there. You see a cement block shack costs less than a nice factory built double wide, or a stick built American home. Same for a wood stove or a propane cook top, dirt floors, and a wash tub over a quality stainless steel kitchen sink.
I don't think it's too much to ask for, not like an expensive fire clay farm house sink, or 24k gold plated plumbing fixtures.
Considering It.
Not sure if I will keep the imperials, sell them, or just let the delivery guys haul them away.
Malcolm
The folks at Reviewed.com sure like it!
CR tested the model up--the 617-- and gave it a composite score of 63 (for comparison, CR's highest rated washer, a Samsung, received an 85). Washing performance received an Excellent. Energy/water usage, capacity and noise were Very Good. The dings came with resistance to vibration (Good) and gentleness to fabrics (Fair). Cycle time was 85 minutes (heaviest soil setting on the Normal cycle; warm (75-degree) water).
Interestingly, the E-Lux 417 was the lowest-rated front-loader, scoring only a 33. Major dings for energy efficiency (Good) and gentleness (Poor). Washing performance was Excellent. Since water efficiency for the model was Very Good, I'm guessing the energy score is reflective of the maximum spin speed. A Frigidaire was the second-lowest rated machine.
Again, for purposes of comparison, the top-rated Samsung received Excellents in everything but noise and vibration, which received Very Good. The behemoth Samsungs and LGs won't even fit through the doorways inside my house.
The Electrolux is a standard 27" wide and has 4.4 cu. ft. drum, nearly identical to my Maytag 8100.
Go for it, Malcolm. Electrolux isn't available in my village and I'm kinda finished with the whole Frigi/Lux brand. I lucked out and got a TOL Frigidaire double-oven range before they de-featured it; they've done the same to their front-load washer line. It's a shame. Looks like Electrolux wants Frigidaire to be their 'budget' line. 😫[this post was last edited: 7/12/2016-12:04]
http://laundry.reviewed.com/content/electrolux-efls517stt-efls517siw-washing-machine-review
