Old car radio
Existing wiring
Can't see why it wouldn't be compatible ? It's a 6 volt bulb, and used in my case as turn signals, so that they won't be running continually. We'l see. Id really like to get brighter lights for the stop/tail lights,1158 in my case, but may have to live with it, unless I can maybe modify a flashlight reflector to the light assembly or some such mess as that ? LOL
Stan, yeah, I think I was getting carried away with the wiring thing.  I had occasion this afternoon to talk with a guy who specializes in auto electrical work, including vintage.  He said he saw no problem with switching out a 63 for an 81.
For adding a reflective surface in your tail, parking and/or signal lamp assemblies, before you buy paint, try one of those shiny metallic pleated baking cups (for cupcakes).   I've read on an old car forum that they're quite effective.
Vaccum fuel pump
Stan, AC (and maybe others) made a double diaphragm fuel pump that helped provide a vacuum boost to the wipers when the car was pulling hard and the manifold vacuum was low. I never had a car with one, but I've heard it was a poor substitute for electric wipers, though better than nothing.
Stan,
The vacuum gas pump combo can be identified by having two lines coming off it. One is a line from the lower part carrying gasoline to the carburetor, the other is a line from the upper part to the vacuum wiper circuit. It's supposed to add vacuum power at times when the intake manifold has low vacuum (such as low speed uphill open throttle). I'll have to take another look at how it's plumbed in.
When I rebuilt the motor in the 90's, I also rebuilt the gas/vac pump. The gas pump works fine, but I think the vacuum part may need some attention, since the wipers can slow down quite a bit uphill. I could probably service it without removing it, but to do anything one must jack up the passenger side the car, remove the front wheel, remove a splash shield, and remove a heat shield over the combo pump. I need to replace the exhaust manifold gasket anyway so I'll probably combine those two repairs when I get a round toit.
[this post was last edited: 11/10/2017-01:44]
Stan,
I got a few #81 bulbs through NAPA.  They make quite a difference.
I took the attached picture after switching out only the left tail lamp.  This was in a shaded area during the day, and you can easily see the difference with the left lens (81 bulb) being fully lit while only the bottom half of the right lens (63 bulb) is lit.  These lamp assemblies hold two separate bulbs -- one for stop and the other for tail.  The tail bulbs are at the very bottom of the assembly and the stop lamps are pretty much right behind the round portion in the center of the lens.  This is why only the bottom half is lit on the right.
At night the entire lens will light up, even with a 63 bulb, but the 81 is twice as bright and brings the illumination up to more modern standards.   This should provide a major improvement on your Plymouth.
..interesting thread that I haven't finished reading, but ...I just inherited some old parts. One is an unused Motorola 2N176 Transistor with a date marking of 152 (1951, the 52nd week).
The link below was also helpful...and within a week, this thread appears.
Thanks for putting this out, Stan -cool old radio and new to my eyes. Tubes!
http://semiconductormuseum.com/PhotoGallery/PhotoGallery_Motorola_2N176.htm
One thing: Most LED lights (bare bones) will run on 6 volts just fine. I added some small blue lenses to the tail-lights on my 50. They fit perfectly into hole that the unlighted red reflector once resided. I added a white LED behind each one, and they glow dimly (back in the 90's, bare bones LED bulbs were relatively low power/lumens. I could probably revisit that and put in more powerful LED's today. But I kind of like the subtle purple glow they give at night.
Rich, those blue dot lenses are popular among customizers.  I do tend to see them on GM cars more than other makes.  I don't know what their purpose is, but I do notice when I come up behind a car with blue dots, the lens appears to light up pink.
This is the best example I've found (on a '56 Chevy):
picture.php
They make the type that would fit on my truck, but the only custom thing about that beast is its patina.  Plain red is fine.  I ordered glass lenses but they're way too dark.  Even with an 81 tail lamp bulb they'd be insufficient, and when stopping, only the round section in the center lights up.  I'm sticking with plastic, and with those the entire lens also serves as a reflector.
Well, Ralph I know the blue dot lenses are very popular with hot rodders. They are also marginally illegal, since only law enforcement vehicles are supposed to display blue lights to the rear. While I've never had a cop pull me over in the Plymouth, it is a reason why I haven't been too anxious to add more illumination to the blue dots.
Come to think of it, I didn't use LED's behind the blue dots after all. Just 6 volt wheat bulbs. I've *thought* of going the LED route, but it would't be quite vintage, would it?
Ralph
Glad the 81s worked for you.
Sounds like you have a different set up the me, and looks like you don't have turn signals on the back?
The 81s (formerly 63s) serve as turn signal for front and back on mine, and 1158s serve as tail/stop lights. The 81s will serve as running lights on the front (but haven't figured out why their not working..yet)
The women at NAPA looked to see if she could find a 6volt dual filiment bulb with more CP that would replace the 1158s but no luck.
So I'm going to try the cupcake liner next. I'll see if it helps. LOL
Rich.
Thank for the info about the gas pump. Mine has been changed to a 6 volt elecric fuel pump.
Have you pull your radio yet? Also I'm curious to know if you have replaced your front or rear windshield gasket on your 50.
Its something that I need to do on mine, and wondering what I might be getting myself into.
Stan,
Havn't pulled the radio yet. It's on my list.
No I didn't replace the front/rear glass gaskets. Although they look easier than on most cars, since I'm guessing the interior fake wood molding actually holds the glass in place against the gasket (That is, squeezes the gasket over the glass). I suppose it's in the service manual.
About seven years ago when for some reason I was leaving the car exposed in the rain, I noticed the windshield was seeping water. A little silicone sparingly applied seemed to resolve that. But eventually it will need a new gasket, I'm sure.
All this discussion about bulbs makes me wonder what's in there. I remember getting 6 volt bulbs at Grand Auto or Kragen back in the 90's . Grand Auto is gone, now there's Auto Zone. No idea what numbers went where, but they all work pretty good.
Oh, by the way. When I rebuilt the Plymouth radio, the tuning pointer fell off. I scrounged around and finally found that a little red tube from a spray can fit pretty well, so that's what's in there now.
Stan, my truck has after-market turn signals.  The rear ones are mounted up near the top of the tailgate and the front are on the flat area behind the front bumper.   They use a single filament bulb, and I have 1129 types, which are rated at 21 CP, in all of them.  I think 21 CP is common for 6 volt stop and signal applications.
If you're using 81s for your turn signals, I can see how those would still be dim, particularly during the day.   The 1129 is more than three times brighter than an 81, and seven times brighter than a 63.
When I had the set of after market tail lamps on the truck, they took a dual filament bulb with the same specs as the 1158, but with offset posts on the side of the bulb (1154).  They lit up well.   I guess the purpose of offset posts is to prevent the reversal of stop and tail filaments.
Thanks Ralph
So.. You think I should try the 1129 for my signals? Just got the 81s that are better than I had.. But if 1129 will show up better during the day I'll try em. My posts are not off set?
Rich, I have to change the gaskets cuz they both leak. It's the rear window that causes me to pause.. The molding is more comlpex, and the glass is curved.. If I broke it, it'd be much hard to find another, where as the fronts are just two flats.
Guess this thread should have been titled "pre 12 volt cars"
LOL
Stan, it just occurred to me that if your signal assemblies use 81s, the 1129 won't fit.  The 1129 base is larger.  It seems odd to me though, that Plymouth would have thought 3 CP (63) was adequate for a turn signal.
Per NAPA's site, front and rear signals on a '50 Plymouth use 1158s.  Do you have more than one socket behind front and rear lenses?  I don't know why there would be, as one 1158 should serve as stop/tail/signal/parking on the rear, and signal/parking up front.  I'm puzzled about how a 63 or 81 comes into play.  If you can, post a couple of pictures here of what's behind front and rear lenses.   Otherwise, maybe Rich can share what's on his car.
Also, on a chart I checked, I noticed that modern 12 volt dual filament stop and tail bulbs aren't any brighter than a 6 volt 1158.  It seems 3 CP is standard across both voltages for tail lamps, and 21 CP or thereabouts for stop/signal.
[this post was last edited: 11/19/2017-00:19]
Re. Vacuum wipers
I'm surprised it doesn't have electric wipers. I thought all. Chrysler products did after 48. My 53 Plymouth did and my 53. Imperial had 2 speed electrics
Technically the Plymouth is a Chrysler "product", but as with other advances, electric wipers hadn't trickled down to the smallest of the Chrysler product lineup by 1950. Similar for automatic transmissions - the Plymouths came only with manual transmissions. Which probably was a good thing, since what Chrysler had in 1950 was a hybrid manual trans with a fluid coupling called "Fluid Drive". Also known as a slush-o-matic.
From Wikipedia:
"Fluid Drive is the trademarked name that Chrysler Corporation assigned to a transmission driveline combination which replaced the flywheel with a hydraulic coupling inserted in and performed the same function as a modern torque converter, only without torque multiplication. A conventional clutch and three- or four-speed manual transmission was installed behind the fluid coupling. Fluid drive was used in many military vehicles produced for the US Armed Forces during the Second World War. It was offered for civilian use from 1939 through 1953 in Chryslers, 1940 through 1953 in DeSotos, and from 1941 through 1954 in Dodge models; a semi-automatic system was optional from Chrysler and Desoto from 1941, and for Dodge from 1949"
Ralph
Your right., Two sockets, two bulbs
Here's the front set up behind the lense.
This is the passenger side front. The bulb showing on the left is the turn signal. The socket just left of it is where the parking or running light is suppose to be, and will also except a bulb 63 or 81.
The back lights are similar, with bulb 63 or 81 used as turn signal, and a separate socket uses a 1158 as a tail/stop.
It's become obvious to me that this car did not come with turn signals from the factory..
As you can see, my problem is that who ever added the turn signals inserted the sockets from the back, this causes the bulb to be too deeply set, and makes it difficult to change bulbs, and also interferes with brightness. I've clipped the wire to one on back and tried to insert the socket from the front (as it should have been done) but won't fit unless I remove the lense assembly and use a drumrel to remove a little more material tword the back, And it appears that's what I'm going to have to do with all four.
Turn signals? On a '50???
LOL.
I still have to stick my arm out the door. Amazing how many other drivers don't have a clue what I'm trying to tell them...
Well at least my '50 has brake lights...
Stan,
In my research on bulbs I've come across some discussions about aftermarket turn signals.  Though I'm not clear on the reasoning, in order to integrate turn signal operation with an existing two-filament stop/tail bulb like an 1158, the signal activator needs to have seven wires.  I got lost trying to follow where all seven of them go.  If the activator has only four wires, separate dedicated signal bulbs are required front (perhaps) and rear.  I'm guessing you're dealing with a four wire system, just like I am on the GMC.
We've established that the added-on signal sockets front and rear can't accept a bulb that's brighter than 6 CP.  In order to allow for a brighter bulb like an 1129, you'll need to upgrade the rear signal sockets to the next larger size.  As long as you have to snip the wires, you might as well dremel the holes so they'll accept the larger socket for an 1129.
Up front, it seems like you have two options:
1)  Do the same thing as on the rear with the dremel and install new larger sockets for 1129s
OR if it's not too difficult,
2)  Snip the wires to both the signal and parking lamp sockets.  Change the parking sockets to dual filament types that accept 1158 bulbs, then connect signal lead and parking lead to the new socket (the added-on signal receptacle is no longer used).  If the wrong filaments light for signal and parking, remove the bulb, turn it 180 degrees and replace.  Both the 1158 and 1129 are available in amber, which would be easier for opposing traffic to notice.
I don't see any other solutions to correct what seems to be a botched installation (front and rear) by one of the car's previous owners.
In my collection of odds and ends for the '50, I have an aftermarket turn signal lever, that you're supposed to clamp to the steering column. But I gather that's the easiest part. Figuring out how to wire it all up would be a challenge. I see that six volt positive ground thermal flashers are available on eBay... But still, easier just to roll down the window and wave wildly, LOL. It's why in winter I always wear a coat while driving.
When I was very young we had an old pre-49 Plymouth. I remember imitating my dad by sticking my arm out the driver side rear seat window. And getting yelled at. Good times.
More
I called a local lighting distributor and inquired about brighter bulbs.  I had found the 1133 type, but they're too big.  Satco shows on their site that they have 1133 in the normal size and shape, equivalent to an 1129 or 1158, but the distributor couldn't find that particular item number.  He suggested a 1680 bulb.  That one looks like what I need.  It's the same size as 1129, but is 32 CP.
Stan, in thinking about your tail lights, since the signal operates on a separate bulb and is at maximum only 6 CP, while you have your foot on the brake, the 21 CP of the 1158 renders the signal lamp invisible (since unlike factory systems, your signal function doesn't supersede the brake).  Seeing as how the brake lamp stays lit while the signal flashes, the only way you'd get any visibility would be to install 1680s back there for your signals.  As stated above, this would require changing the existing socket to the larger size and using the dremel to make the hole larger.
I may order a 10-pack of 1680s.  If you decide to upgrade, I'll have a couple of spares that I could send to you.
http://www.bulbtown.com/1680_Miniature_Bulb_Ba15s_Base_p/1680.htm
As far as wiring the aftermarket turn signal thing lots of old jeeps and power wagons and other old trucks got them back in the day so there should be basic instructions on how to wire one up out there somewhere. I bet Google would find some somebody has archived. My buddy had one in his 55 dodge pick up that had a rubber wheel that ran on the edge of the steering wheel so it could self cancel like modern cars and it worked. My Jeep never had turn signals installed just the standard military black out light switch it left the factory with. It was cool because you really could run in total blackout mode and nothing lit up. I used to just turn on the brake lights during the day. My power wagon had a aftermarket setup installed and working when I got it. I did rip the setup out of a car at a yard but never put it in my jeep.
I spose somebody still sells them but not many cars that old running around now.
Thanks Ralph
Let me know how the 1680s work for you. I'm glad to know there is a way (option 1) that I can Get some brightness. I suppose I could get or order a 1680 bulb and have NAPA hook me up with a corresponding socket, then cut my cloth to fit. I picked up a new universal socket that fits a 63 or 81 but would need some fine tuning to mount it, as the existing sockets have a different set up.
Rick
Nice 50! Why the two side mirrors on one door? Was thinking about ur radio and assumed that back when u installed, you used the trimming screw to fine tune. If u didn't you might try that to increase its volume. I believe it was recommended at the time a antenna was changed. (re trimmed)
Terry
My signals are not self cancelling. Anyone riding with me finds it hilarious.
Yep, the older cars didn't always get turn signals or self canceling, but by 50 I'd think most cars had simple signals. I only ever saw that one aftermarket upgrade turn signal system with self canceling on my buddies Dodge pickup. I bet it was much more expensive than others and the steering wheel hub had to have enough area and all that for the wheel to work. My Dart the tabs internally broke, one after the other, shortly after I got it so the cancel feature stopped working. I bought a kit to fix it but realized it was kinda cheap and I would have to cut wires so I never installed it. So when I used to drive it it worked just like your 50. I had a 50 coronet I never got running for a few years with a fuid drive semi auto transmission. It was a cool car and the body was solid and straight and I was given a ton of spare parts for it. Long gone now, I sold it for 200 nucks and the guy pulled one fenderand hopefully kept the parts and gave it to a wrecking yard where I found it again.
Well, I think Stan has an aftermarket turn signal control, and since those generally are not integrated into the steering mechanism, they generally won't self cancel.
For that matter, a previous owner of my '67 Chevy replaced the stock steering wheel with a smaller padded aftermarket steering wheel. In the process, the ability to cancel the turn signal was lost. I'd actually like to round up the correct steering wheel for that vehicle, along with replacing the turn signal mechanicals inside the hub. It's on my bucket list. Meanwhile, I've got kind of used to having to cancel the turn signal manually.
Well they made that body style for a few years as far as your pickup so I bet you can choose from and chevy pickup with a similar body and use the steering wheel from it.
My Dart most of the parts from 67 to 76 when they stopped making them can be interchange or at least modified to fit easily.
I got my big bolt disk brake upgrade parts I never installed from a 75 Dart 4 door I bought for 150 and drove home. The brake parts alone were worth more then I paid for the car. Luckily the car itself was god awful ugly so nobody would buy it from him even for 150, but I asked what brakes it had and if they worked so I went out and paid him cash with no argument.
All the parts will pretty much bolt in to my 69.
It's not a pickup, it's a van. A pickup steering wheel might fit, I don't know. The vans were a bit different, albeit primarily, besides the obvious sheet metal difference, in the engine placement and front suspension. And the linkages.
At some point I also want to rewire the van completely. Someone put a Clifford alarm in it and it's like some creature from Star Trek, like a parasite on the nervous system. It's spliced into the original wiring harness in multiple places, and there are melted wires in there too. For some reason the wiring in the steering wheel area is especially strange.
The 1680 bulbs are supposed to arrive on Monday.  Weather permitting, I may try them out if they don't arrive too late in the day, otherwise on Tuesday.  I'll report in with the results.
