Stan,
In my research on bulbs I've come across some discussions about aftermarket turn signals.  Though I'm not clear on the reasoning, in order to integrate turn signal operation with an existing two-filament stop/tail bulb like an 1158, the signal activator needs to have seven wires.  I got lost trying to follow where all seven of them go.  If the activator has only four wires, separate dedicated signal bulbs are required front (perhaps) and rear.  I'm guessing you're dealing with a four wire system, just like I am on the GMC.
We've established that the added-on signal sockets front and rear can't accept a bulb that's brighter than 6 CP.  In order to allow for a brighter bulb like an 1129, you'll need to upgrade the rear signal sockets to the next larger size.  As long as you have to snip the wires, you might as well dremel the holes so they'll accept the larger socket for an 1129.
Up front, it seems like you have two options:
1)  Do the same thing as on the rear with the dremel and install new larger sockets for 1129s
OR if it's not too difficult,
2)  Snip the wires to both the signal and parking lamp sockets.  Change the parking sockets to dual filament types that accept 1158 bulbs, then connect signal lead and parking lead to the new socket (the added-on signal receptacle is no longer used).  If the wrong filaments light for signal and parking, remove the bulb, turn it 180 degrees and replace.  Both the 1158 and 1129 are available in amber, which would be easier for opposing traffic to notice.
I don't see any other solutions to correct what seems to be a botched installation (front and rear) by one of the car's previous owners.
