OUT WITH THE OLD IN WITH THE NEW!
Aferim!
That is an AMAZING restoration.
Loved the lasagne ribbon and bow. I think you could have gotten Mr. and Mrs. Stewart to come and pose for that pictures such a good job you did. Or at least the Dachshund. It looks like you polished and painted every component.
Painting
The only painting I did was on secondary parts which were not primed.That would be the base and all grey parts.The base was the only thing that really needed to be painted.The other parts were in good condition.But the OCD kicked in and I painted them anyway.Did the same with the 57 Philco Bendix Duomatic.
IT'S ORIGINAL HOME
This is one of the pictures the seller sent me.This is where the machine was installed when it was brand new.And it was in storage for about 9 months before I got it.
"Out with the old..." I guess the old is taken to the curb for the junkmen.
NO. Something one wouldn't think of doing today.
You have done an INCREDIBLE job !
It looks fresh from the crate. Your laundry room looks spiffy, too.
Perhaps it was the heat from a dryer that saved this. The heat chased away humidity that would have made your job much worse.
Did you have to make parts, like the boot? other gaskets?
Very impressive given the amount of time and patiences that went into this.
PARTS REPAIR
I replaced ALL hoses and the pump diaphram needed to be repaired because of a 3" tear.Thank God for nylon thread.Seems to be holding well.Should this fail in time I will convert to an electric pump which would intail moving things around under the machine so it can pump the water the way it should.These diaphrams should have been reinforced like heater hose is.They may have lasted longer.All other rubber parts on machine were fine.
Combos
I really expected combos to have made a comeback in the US market by now! What's the holdup Whirlpool?
Malcolm
1957 Whirlpool combo
WOW John you never fail to amaze me with your skills at doing just about anything. Now you have me even more excited about  picking up the 1958 Gas Combo in Indiana next week  and of course getting to see you and your new machine when I get to Minnesota the following week.
I would have replied sooner but we just finished the 15th load of dishes from our holiday party for our car club this morning. I took some pictures of the loads of dishes before and after they were run, we had over 65 people for dinner.
TIME TO COMPLETE CYCLE
I never timed the wash 10 min wash plus 3 rinses.I would say about 20min max.Dry time depends on size of load and what it is.I have never dried anything more than an hour and a half.I did a test load of 8 bath towls and they dried in 1hr 15 min.good size load of t-shirts and socks took about an hour.I was surprised how well it dries with such a slow spin.
If hot wash is used, possible additional time may be needed/used to heat the wash water up to 140 degbrees after it enters a cold cabinet.  Maybe a minute for every1.5 degrees given it's a 4300 watt water heater.
incredible machine and restoration
That is an outstanding restoration and machine,the best example I have seen of one of those.Totally fascininating,great pictures.This is one of my favorite things to find on this site these detailed restorations,would love to see more like this.What is the story with the bendix in the first photo?That is the same one I have.Mine currently doesnt run,motor just hums.
The sound you just heard was my jaw hitting the floor. WOW! That RCA Whirlpool combo looks like it just stepped off the showroom floor. Absolutely stunning. Once again, I have to tip my hat to those of you with the know-how and the patience to do such beautiful work.
Beautiful Bendix, as well, John. Is it stable on that riser? I'd be so fearful of a machine vibrating or walking off one of those things.
Steal Stand
My Dad welded the steal stand for me, which is bolted to the floor and the bendix is bolted to it.Very solid no shaking at all.
Absolutely fabulous, John!! Congratulations for a job well done.
Just out of curiosity, how does the spin speed of this compare to that of the Westinghouse front loaders of the same vintage? I believe the spun at 500 something rpms. Also, how well does it handle out of balance loads.
Barry
The WP spins at 200 rpms.  If mechanically set properly, it's somewhat sensitive to off balanced loads and will stop and rebalance.  At least with the LK that lived next door to me did.
RCA Combo Balance
This machine has a great balance system.The machine will never walk if installed the right way.Even if it has a large heavy load.I have less than 1/4" on each side of the machine.More than enough room on each side.
