bradross
Location of drain on the Kenmore...
Hello again, Tim (wayupnorth) ... sorry, I wasn't following what you were getting at. Yes, indeed, the drain is at the side, NOT under the agitator (as in a Maytag, Speed Queen, and perhaps some others.) The bottom of the tub has a slight incline towards the drain. When you said "at the side" I thought you meant a gravity drain valve on the outside, without a hose.
Regarding the black bakelite agitators, I assume they were standard in the '50s, after my model. Perhaps somebody in the know can verify that. I was thrilled to get this '48 model with the cast aluminum agitator! I wonder, however, if it originally had a metal cap.
