beko
Hi Richard , did you use the "normal Dry" setting? or Damp Dry,
Does this dryer have heat setting as well as the sensor setting, With The Zug you set the sensor setting, say normal dry but then you can also set lower temp or much lower temp setting which is great for synthetics delicates and woollens..
